주요 콘텐츠로 건너뛰기
How to Remove the Scratches from an Acrylic Watch Face
필요한 것
  1. How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: 1 단계, 이미지 2개 중 1개 How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: 1 단계, 이미지 2개 중 2개
    • Examine the damage and identify the boundaries for buffing the face of the watch.
    • Working with sandpaper can damage other areas of the watch, so understanding your working area will prevent any careless mistakes.
  2. How to Remove the Scratches from an Acrylic Watch Face: 2 단계, 이미지 3개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 2 단계, 이미지 3개 중 2개 How to Remove the Scratches from an Acrylic Watch Face: 2 단계, 이미지 3개 중 3개
    • Wipe the watch surface with a paper towel dampened with isopropyl alcohol.
    • It is important to clean the watch of any surface debris to prevent making new scratches.
  3. How to Remove the Scratches from an Acrylic Watch Face: 3 단계, 이미지 3개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 3 단계, 이미지 3개 중 2개 How to Remove the Scratches from an Acrylic Watch Face: 3 단계, 이미지 3개 중 3개
    • Use the 1000-grit sandpaper, and gently sand the face of the watch in a circular motion.
    • This step is to remove any deep scratches.
  4. How to Remove the Scratches from an Acrylic Watch Face: 4 단계, 이미지 3개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 4 단계, 이미지 3개 중 2개 How to Remove the Scratches from an Acrylic Watch Face: 4 단계, 이미지 3개 중 3개
    • With your fingernail, feel the surface of the watch for any remaining deep scratches.
    • Keep sanding until you no longer feel scratches.
  5. How to Remove the Scratches from an Acrylic Watch Face: 5 단계, 이미지 2개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 5 단계, 이미지 2개 중 2개
    • Clean the surface again with a paper towel and isopropyl alcohol to prep the watch face for polishing.
  6. How to Remove the Scratches from an Acrylic Watch Face: 6 단계, 이미지 2개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 6 단계, 이미지 2개 중 2개
    • With the tube of polyWatch, place a small dab of the polishing compound on the face of the watch.
  7. How to Remove the Scratches from an Acrylic Watch Face: 7 단계, 이미지 3개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 7 단계, 이미지 3개 중 2개 How to Remove the Scratches from an Acrylic Watch Face: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • With the microfiber cloth, begin working on the face of the watch in a circular motion for at least 2-3 minutes.
    • Wipe away any excess compound with a clean cloth and examine your results.
  8. How to Remove the Scratches from an Acrylic Watch Face: 8 단계, 이미지 2개 중 1개 How to Remove the Scratches from an Acrylic Watch Face: 8 단계, 이미지 2개 중 2개
    • Repeat the process until you are satisfied with the results.
결론
Now, your watch should look close to the day you bought it!
작성자
4다른 기여자 명과 함께
Lloyd Derryk Alba
회원 가입일: 09/20/23
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 15
지난 30일: 59
전체 시간: 1,676
