주요 콘텐츠로 건너뛰기
How to Remove the Stand on a PlayStation 5
필요한 것
  1. How to Remove the Stand on a PlayStation 5, Remove the stand screw: 1 단계, 이미지 1개 중 1개
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Remove the Stand on a PlayStation 5, Remove the vertical stand: 2 단계, 이미지 2개 중 1개 How to Remove the Stand on a PlayStation 5, Remove the vertical stand: 2 단계, 이미지 2개 중 2개
    • Lift straight up to remove the stand.
  3. How to Remove the Stand on a PlayStation 5, Store the stand screw: 3 단계, 이미지 2개 중 1개 How to Remove the Stand on a PlayStation 5, Store the stand screw: 3 단계, 이미지 2개 중 2개
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Remove the Stand on a PlayStation 5, Cap the screw hole: 4 단계, 이미지 3개 중 1개 How to Remove the Stand on a PlayStation 5, Cap the screw hole: 4 단계, 이미지 3개 중 2개 How to Remove the Stand on a PlayStation 5, Cap the screw hole: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Remove the Stand on a PlayStation 5, Close the cubby: 5 단계, 이미지 3개 중 1개 How to Remove the Stand on a PlayStation 5, Close the cubby: 5 단계, 이미지 3개 중 2개 How to Remove the Stand on a PlayStation 5, Close the cubby: 5 단계, 이미지 3개 중 3개
    • Twist the stand counterclockwise to close the cubby.
  6. How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: 6 단계, 이미지 2개 중 1개 How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: 6 단계, 이미지 2개 중 2개
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
31,676 평판
안내서 94개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 138
지난 30일: 549
전체 시간: 57,358
