주요 콘텐츠로 건너뛰기
How to Remove the Top Panel in Your LG WM3050CW Washing Machine
필요한 것
  1. How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Safety Precautions: 1 단계, 이미지 2개 중 1개 How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Remove the top panel: 3 단계, 이미지 2개 중 1개 How to Remove the Top Panel in Your LG WM3050CW Washing Machine, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. How to Remove the Top Panel in Your LG WM3050CW Washing Machine: 4 단계, 이미지 2개 중 1개 How to Remove the Top Panel in Your LG WM3050CW Washing Machine: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,555 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 62
전체 시간: 560
