주요 콘텐츠로 건너뛰기
How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
필요한 것
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: 1 단계, 이미지 1/2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: 1 단계, 이미지 2/2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 2 단계, 이미지 1/1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 3 단계, 이미지 1/1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 4 단계, 이미지 1/1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 5 단계, 이미지 1/1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 6 단계, 이미지 1/2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 6 단계, 이미지 2/2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Pearce McKee
회원 가입일: 03/31/20
133 평판
안내서 1개 작성함
University of Memphis, Team S5-G1, Willis Spring 2020 University of Memphis, Team S5-G1, Willis Spring 2020 회원
UM-WILLIS-S20S5G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 68
전체 시간: 1,343
