주요 콘텐츠로 건너뛰기
How to Repaint Your Garage Floor
필요한 것
  1. How to Repaint Your Garage Floor, How to Repaint Your Garage Floor: 1 단계, 이미지 1개 중 1개
    • Use a paint scraper to remove the old paint from the area where you want to apply the new paint.
    • It's okay if there is still some old paint left on the surface.
    • Paint cracks usually indicate corrosion and require scraping.
  2. How to Repaint Your Garage Floor: 2 단계, 이미지 1개 중 1개
    • Remove debris and dust with a broom.
  3. How to Repaint Your Garage Floor: 3 단계, 이미지 1개 중 1개
    • Examine the quality of your paint.
    • If it is too thick, and you're using water-based paint, mix in a little bit of water.
    • If it is too thick, and you're using an oil-based paint, add paint thinner.
  4. How to Repaint Your Garage Floor: 4 단계, 이미지 1개 중 1개
    • Wet the surface of the roller with water.
  5. How to Repaint Your Garage Floor: 5 단계, 이미지 2개 중 1개 How to Repaint Your Garage Floor: 5 단계, 이미지 2개 중 2개
    • Pour the paint in a container, dip your roller in, and start rolling.
    • You can also use a paint brush.
  6. How to Repaint Your Garage Floor: 6 단계, 이미지 1개 중 1개
    • New paint has been applied and you can see the direct contrast.
    • When the paint has dried, reapply a second coat of paint.
  7. How to Repaint Your Garage Floor: 7 단계, 이미지 1개 중 1개
    • Collect all the tools and prepare them for cleaning.
    • For water-based paint, rinse the tools in water. For oil-based paint, rinse the tools in paint thinner.
    • When rinsing, don't dip your tools in your paint thinner container directly. Instead, pour the paint thinner into another container that can be used for rinsing the tools.
결론
Follow these instructions so you can be the next person to learn how to paint.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Chao Zheng
회원 가입일: 09/20/20
177 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 1,123
