주요 콘텐츠로 건너뛰기
How to Repair A Damaged Book Cover
필요한 것
  1. How to Repair A Damaged  Book Cover, How to Repair A Damaged  Book Cover: 1 단계, 이미지 1/1
    • Lay the ConTact Paper on a smooth, clean surface.
    • Make sure the adhesive side is face down so that the white paper is facing you.
    • Place your book on the ConTact paper.
  2. How to Repair A Damaged  Book Cover: 2 단계, 이미지 1/1
    • Wrap the ConTact Paper over your book, measuring out enough to completely cover the book.
  3. How to Repair A Damaged  Book Cover: 3 단계, 이미지 1/1
    • Place a paperweight on the side of the folded paper to prevent curling. Or even the scissors you're using (as shown) to hold down the corner of the paper.
    • Flatten the edge of the ConTact Paper along the spine of your book.
  4. How to Repair A Damaged  Book Cover: 4 단계, 이미지 1/1
    • Cut the ConTact Paper from the roll, keeping to the length measured to cover your entire book.
  5. How to Repair A Damaged  Book Cover: 5 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 5 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 5 단계, 이미지 3/3
    • Once the extra ConTact Paper is discarded, cut the ConTact Paper diagonally towards the spine of your book.
    • Repeat this cut on the other side of the spine.
    • Your finished cut should have a 'v' shape pointing towards the spine of the book
  6. How to Repair A Damaged  Book Cover: 6 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 6 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 6 단계, 이미지 3/3
    • With the cover of your book laying flat against the left side of the paper, peel back the right half of the paper from the laminate film.
    • Make sure to peel the paper back until the focal point of the 'V' is exposed.
    • Fold the edge of the laminate film onto the table to prevent sliding and bubbles.
  7. How to Repair A Damaged  Book Cover: 7 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 7 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 7 단계, 이미지 3/3
    • Place the top edge of your book to the top edge of the center of the laminate film.
    • Using a rolling motion, slowly stick the rest of the spine to the laminate.
    • Using the same motion, slowly roll one side of the textbook over the exposed film.
    • Roll onto the laminate slowly and evenly to prevent bubbles in your lamination.
  8. How to Repair A Damaged  Book Cover: 8 단계, 이미지 1/2 How to Repair A Damaged  Book Cover: 8 단계, 이미지 2/2
    • Unfold the laminate from the table and cut to the edges similar to Step 4
    • The finished edges will look like an inverted 'v'
  9. How to Repair A Damaged  Book Cover: 9 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 9 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 9 단계, 이미지 3/3
    • Fold the edges onto the inside cover of the textbook. Start with the top of the book cover, folding the vertical edge of the book last.
  10. How to Repair A Damaged  Book Cover: 10 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 10 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 10 단계, 이미지 3/3
    • Remove the rest of the paper from the laminate film.
    • Repeat motions from step 7 and slowly roll your book cover onto the laminate film.
  11. How to Repair A Damaged  Book Cover: 11 단계, 이미지 1/3 How to Repair A Damaged  Book Cover: 11 단계, 이미지 2/3 How to Repair A Damaged  Book Cover: 11 단계, 이미지 3/3
    • Repeat steps 8 and 9 to cut and secure lamination.
    • Trim any remaining lamination film to complete the project.
결론
If you have followed the previous steps, your textbook should now be mended and resistant to further damage.
다른 한 분이 해당 안내서를 완성하였습니다.
Stephaney Ferguson
회원 가입일: 03/15/17
125 평판
안내서 1개 작성함
Missouri Western, Team S40-G7, Kunkel Spring 2017 Missouri Western, Team S40-G7, Kunkel Spring 2017 회원
MWSU-KUNKEL-S17S40G7
2 회원들
안내서 3개 작성하였습니다
댓글 한 개
The original cover was completely destroyed by water and am unable to follow your instructions. Can't I just purchase a new cover?
ryanmary - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 48
30일 전: 160
전체 시간: 16,662
