주요 콘텐츠로 건너뛰기
How to Repair A Wet Book
필요한 것
  1. How to Repair A Wet Book, How to Repair A Wet Book: 1 단계, 이미지 1개 중 1개
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: 2 단계, 이미지 1개 중 1개
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: 3 단계, 이미지 2개 중 1개 How to Repair A Wet Book: 3 단계, 이미지 2개 중 2개
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: 4 단계, 이미지 2개 중 1개 How to Repair A Wet Book: 4 단계, 이미지 2개 중 2개
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: 5 단계, 이미지 1개 중 1개
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: 6 단계, 이미지 1개 중 1개
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: 7 단계, 이미지 2개 중 1개 How to Repair A Wet Book: 7 단계, 이미지 2개 중 2개
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: 8 단계, 이미지 1개 중 1개
    • Great job! The book is now restored to its original condition. Happy reading!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lizzy Cox
회원 가입일: 03/07/19
241 평판
안내서 1개를 작성함
2가이드 댓글
because im in middle school. and it is sters full with wet books
Hazen Harwood - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 148
전체 시간: 2,086
