주요 콘텐츠로 건너뛰기
How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On
필요한 것
동영상 개요
  1. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: 1 단계, 이미지 1/1
    • As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
    • There are two contact areas:
    • Between the battery cover and the KB aluminum body
    • Between the power button assemble and the KB aluminum body
    • If the device has a power problem, we need to check and clean these two places
  2. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: 2 단계, 이미지 1/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: 2 단계, 이미지 2/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: 2 단계, 이미지 3/3
    • Use a Coin to remove the metal battery screw cover
    • Change the batteries (AA) and test the keyboard
    • If the keyboard does not work, go to the next step
  3. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: 3 단계, 이미지 1/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: 3 단계, 이미지 2/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: 3 단계, 이미지 3/3
    • Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
    • Test the device and f the keyboard does not work, go to the next step
  4. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: 4 단계, 이미지 1/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: 4 단계, 이미지 2/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: 4 단계, 이미지 3/3
    • Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
    • There are a screw secured the BT antenna, remove it
    • Slide the board out.
    • Be careful for the KB Flex Cable
  5. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: 5 단계, 이미지 1/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: 5 단계, 이미지 2/3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers or a sharp metal tool and slightly bend the contact plate outwards
    • Clean the tube and the contact plate
    • Install back the logic board plate and be careful for the flex
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 4개
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
George Walsh - 답글
Wow! This fixed actually worked! I was about to thrown this A1314 keyboard out (2009 model)! You can remove the plastic "cap" with a precision flathead screwdriver. Also, be careful when disassembling the ribbon cable - there is a plastic retaining clip holding it in place. Use the precision screwdriver to carefully release the tabs on either side and then pop it out. The ribbon cable will then easily side out. By the way...I'm typing this comment on my newly fixed wireless keyboard! Thanks again!
Vic - 답글
its great having this guide. I got the keyboard to work again.
shinnranchgrouse - 답글
from time to time it makes error sound and interfering apps such as blinking pop up menus ... speaking about MacBook Pro 2017 Monterey
Not to mention that it's not connecting to MacBook Air M1 at all ... )) Goodby my 2009 bluetooth .. Sad ..It is like new and working with other apps except adobe )
Alec - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 54
30일 전: 232
전체 시간: 14,309
