주요 콘텐츠로 건너뛰기
How to Repair Arm Gapes
필요한 것
  1. How to Repair Arm Gapes, How to Repair Arm Gapes: 1 단계, 이미지 1/1
    • Gather the supplies needed.
  2. How to Repair Arm Gapes: 2 단계, 이미지 1/2 How to Repair Arm Gapes: 2 단계, 이미지 2/2
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Repair Arm Gapes: 3 단계, 이미지 1/3 How to Repair Arm Gapes: 3 단계, 이미지 2/3 How to Repair Arm Gapes: 3 단계, 이미지 3/3
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Repair Arm Gapes: 4 단계, 이미지 1/3 How to Repair Arm Gapes: 4 단계, 이미지 2/3 How to Repair Arm Gapes: 4 단계, 이미지 3/3
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Repair Arm Gapes: 5 단계, 이미지 1/1
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Repair Arm Gapes: 6 단계, 이미지 1/1
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
결론
Thank you for taking the time to read this.
Danielle Fontanos
회원 가입일: 10/23/23
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 5-6, Kershman Fall 2023 CSU Los Angeles, Team 5-6, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 116
