주요 콘텐츠로 건너뛰기
How to Repair Automobile Scratches & Paint Chips
필요한 것
  1. How to Repair Automobile Scratches & Paint Chips, How to Repair Automobile Scratches & Paint Chips: 1 단계, 이미지 1/1
    • Check the inside of the driver's side door to find the manufacturer's paint code.
    • This sticker can be found directly next to the VIN number.
    • Use this paint code to order the exact same color paint online or find it at your local hardware store.
  2. How to Repair Automobile Scratches & Paint Chips: 2 단계, 이미지 1/1
    • Fill a medium-sized bucket with warm water and a small amount of soap.
    • A little soap goes a long way.
  3. How to Repair Automobile Scratches & Paint Chips: 3 단계, 이미지 1/3 How to Repair Automobile Scratches & Paint Chips: 3 단계, 이미지 2/3 How to Repair Automobile Scratches & Paint Chips: 3 단계, 이미지 3/3
    • Use soapy water and sponge to wash the car.
    • Rinse off the soap with a water hose.
  4. How to Repair Automobile Scratches & Paint Chips: 4 단계, 이미지 1/1
    • Use a clean towel to dry the freshly washed car.
    • Make sure the area is completely dry before continuing.
  5. How to Repair Automobile Scratches & Paint Chips: 5 단계, 이미지 1/1
    • Use sandpaper to buff out scratches. Start from 150 and continue until 400 grit.
    • This levels out the area so the paint will be applied evenly.
  6. How to Repair Automobile Scratches & Paint Chips: 6 단계, 이미지 1/2 How to Repair Automobile Scratches & Paint Chips: 6 단계, 이미지 2/2
    • Use a small amount of grease remover and a cloth to clean any wax from the area.
  7. How to Repair Automobile Scratches & Paint Chips: 7 단계, 이미지 1/2 How to Repair Automobile Scratches & Paint Chips: 7 단계, 이미지 2/2
    • Starting with a small amount of paint, apply the first coat of paint to the scratched area.
    • Use as little paint as possible to prevent clumping.
    • Wait 15-20 minutes for the coat to fully dry before continuing.
  8. How to Repair Automobile Scratches & Paint Chips: 8 단계, 이미지 1/2 How to Repair Automobile Scratches & Paint Chips: 8 단계, 이미지 2/2
    • If necessary, apply a second coat of paint to the area.
    • This may be necessary for deep scratches or chips.
    • Wait 15-20 minutes before continuing.
    • Continue to reapply if needed.
  9. How to Repair Automobile Scratches & Paint Chips: 9 단계, 이미지 1/3 How to Repair Automobile Scratches & Paint Chips: 9 단계, 이미지 2/3 How to Repair Automobile Scratches & Paint Chips: 9 단계, 이미지 3/3
    • Use the small paintbrush to apply clear coat over the freshly dried paint.
    • Wait 10-15 minutes for the clear coat to dry.
  10. How to Repair Automobile Scratches & Paint Chips: 10 단계, 이미지 1/1
    • Give your car a quick look over to ensure you got every spot.
    • If you missed a spot, no worries. Just go through this guide again.
    • Now your car is as good as new!
결론
After the clear coat has dried, your car’s paint job should be looking like it did the day you drove it off the lot!
다른 한 분이 해당 안내서를 완성하였습니다.
Isaiah Bugarin
회원 가입일: 02/21/22
205 평판
안내서 1개 작성함
University of North Texas, Team 1-7, Smith Spring 2022 University of North Texas, Team 1-7, Smith Spring 2022 회원
UNT-SMITH-S22S1G7
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
Kann man die folgende Sonax Autopolitur für den 6. Schritt verwenden?
Engin Mutlu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 25
30일 전: 95
전체 시간: 1,288
