주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair Broken Makeup Powder
조회수: 1.3천
통계 보기:
지난 24시간
4
지난 7일:
23
지난 30일:
90
전체 시간:
1,271
댓글: 0
해당 안내서에 댓글을 남긴 사람이 없습니다. 첫 번째가 되시겠습니까?
Go to guide comments
완료함: 1
1명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 15 분
난이도: 쉬움
When you drop your makeup powder and crack it, it can get messy because the powder will be broken up and loose. When this happens, it can be upsetting to think that you will need to spend a lot of money to buy a new item of makeup when you still have a lot of the desired product. This guide will teach you how to put the powder back together so that your makeup will be compact again and will help you save your money.
필요한 것
도구
    1. How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: 1 단계, 이미지 2개 중 1개 How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: 1 단계, 이미지 2개 중 2개
      • Set a paper towel down on your workspace to catch any spills during the repair process.
      • Using the toothpick, break up the powder into smaller pieces to ensure that all the product is lifted off of the container that it is held in.
      댓글 쓰기
    2. How to Repair Broken Makeup Powder: 2 단계, 이미지 1개 중 1개
      • Dump the broken powder into a bowl, and tap on the side of the bowl to make sure that all the product is falling in.
      • Using the cotton swab, wipe off as much of the remaining product as possible into the bowl.
      댓글 쓰기
    3. How to Repair Broken Makeup Powder: 3 단계, 이미지 1개 중 1개
      • Add 3 drops of isopropyl alcohol into the bowl of powder.
      댓글 쓰기
    4. How to Repair Broken Makeup Powder: 4 단계, 이미지 1개 중 1개
      • Start mixing the powder and isopropyl alcohol together with the spoon.
      • Continue to add 3 drops of isopropyl alcohol to the bowl at a time until all the powder is wet.
      댓글 쓰기
    5. How to Repair Broken Makeup Powder: 5 단계, 이미지 1개 중 1개
      • Clean the container with paper towels and isopropyl alcohol. This will make sure that the completed project will be looking good as new.
      • Scoop all of the product into the spoon and pour it into the clean container.
      댓글 쓰기
    6. How to Repair Broken Makeup Powder: 6 단계, 이미지 1개 중 1개
      • Once all of the product is in the container, smooth down the surface with your finger. Try to soften as many of the bumps as possible.
      댓글 쓰기
    7. How to Repair Broken Makeup Powder: 7 단계, 이미지 1개 중 1개
      • Use the paper towel to clean up the edges of the container.
      • Let the finished product harden by keeping it unopened for 24-48 hours near a window. Then it will be ready to use.
      댓글 쓰기
결론
The reader will be able to reassemble their broken makeup powder by reading this easy-to-follow tutorial.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Cloe Chin
회원 가입일: 04/10/19
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 90
전체 시간: 1,271
