주요 콘텐츠로 건너뛰기
How to Repair Damaged Door or Window Casing
필요한 것
  1. How to Repair Damaged Door or Window Casing, How to Repair Damaged Door or Window Casing: 1 단계, 이미지 1/1
    • Sand down the damaged area of the trim using the block sanding sponge to make a smooth surface.
  2. How to Repair Damaged Door or Window Casing: 2 단계, 이미지 1/1
    • Wipe off the excess dust from sanding with a wash cloth.
  3. How to Repair Damaged Door or Window Casing: 3 단계, 이미지 1/1
    • Apply Dap drydex spackling to to the damaged area of the trim using a 1" plastic putty knife.
    • Allow the spackling to dry per the directions on the label.
  4. How to Repair Damaged Door or Window Casing: 4 단계, 이미지 1/1
    • Use the block sanding sponge to smooth out the surface of the trim to match the crevices of the trim.
  5. How to Repair Damaged Door or Window Casing: 5 단계, 이미지 1/1
  6. How to Repair Damaged Door or Window Casing: 6 단계, 이미지 1/2 How to Repair Damaged Door or Window Casing: 6 단계, 이미지 2/2
    • Tape the edges around the damaged area of the trim with masking tape.
  7. How to Repair Damaged Door or Window Casing: 7 단계, 이미지 1/2 How to Repair Damaged Door or Window Casing: 7 단계, 이미지 2/2
    • Paint the trim to match the original color.
    • Allow the paint to dry before removing the tape.
결론
Repairing chipped and/or broken door or window casing in the home as a do-it-yourself project overall saves time and money. There is no hassle of having to take off of work to meet the installers, no outrageous costs for materials and proper equipment, and no stress because this guide has everything necessary to complete the repair. So have fun, good luck, and happy fixing.
다른 한 분이 해당 안내서를 완성하였습니다.
Celeste Conroy
회원 가입일: 07/11/17
122 평판
안내서 1개 작성함
Texas Tech, Team S1-G6, Rauch Summer 2017 Texas Tech, Team S1-G6, Rauch Summer 2017 회원
TTU-RAUCH-SU17S1G6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 37
전체 시간: 2,090
