주요 콘텐츠로 건너뛰기
How to Repair Displaced Engine Gears in a Remote Controlled Helicopter
필요한 것
  1. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter, How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 1 단계, 이미지 1/1
    • Locate the problematic engine gear inside the helicopter frame.
    • It will seem out of place and will not connect with the rotor gear.
    • The white gear can be clearly seen out of place and not in contact with the upper rotor gear. This does not allow the blades to spin.
  2. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 2 단계, 이미지 1/1
    • Grab the screwdriver that will fit the screws on your specific model.
    • The screws may not be the same sizes on your RC Heli.
    • Keep track of where the screws came from.
  3. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 3 단계, 이미지 1/2 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 3 단계, 이미지 2/2
    • Unscrew the decorative/protective shroud blocking your access to the inside of the helicopter.
  4. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 4 단계, 이미지 1/1
    • If it is possible to reset the gear without unscrewing further, attempt to push the gear back up into place on the motor shaft with a screwdriver or your finger.
    • If this works you have fixed the gear and can skip to step 7.
    • If the gear is inaccessible you will have to open the frame, go to step 5.
  5. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 5 단계, 이미지 1/2 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 5 단계, 이미지 2/2
    • Unscrew one side of the frame and set it aside, allowing access to the gear.
    • Make sure all the screws and frame pieces are kept in a secure location.
  6. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 6 단계, 이미지 1/2 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 6 단계, 이미지 2/2
    • Place the screwdriver's tip underneath the clear motor gear.
    • Firmly push the gear back up into place so that it correctly connects with the main rotor gear.
    • See the last picture for a proper gear connecion visual.
  7. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 7 단계, 이미지 1/3 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 7 단계, 이미지 2/3 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 7 단계, 이미지 3/3
    • Return all the pieces to their original place inside the frame.
    • Screw the frame tightly back into place.
  8. How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 8 단계, 이미지 1/2 How to Repair Displaced Engine Gears in a Remote Controlled Helicopter: 8 단계, 이미지 2/2
    • Test the helicopter for functionality.
    • If it works then the helicopter is fixed and you can screw the shroud back into place.
결론
To reassemble, after testing for functionality, make sure all inner parts are back in their original location. Screw the frame and shroud tightly back in place.
다른 5명이 해당 안내서를 완성하였습니다.
Neil Wolfe
회원 가입일: 04/09/15
181 평판
안내서 1개 작성함
Cal Poly, Team 30-6, Green Spring 2015 Cal Poly, Team 30-6, Green Spring 2015 회원
CPSU-GREEN-S15S30G6
2 회원들
안내서 3개 작성하였습니다
댓글 2개
Amazing! That repair was genuinely simple to follow directions helped me step by step and I fixed my helicopter for my grandson
Carrie Johnson - 답글
I had two d50's tore one down was a little intimidated until I came to this website and it flies! TY
dio92105 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 41
전체 시간: 6,880
