주요 콘텐츠로 건너뛰기
How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars
필요한 것
  1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars, How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 1 단계, 이미지 1/1
    • Remove the main J0 head screw in the center of the binoculars, using the driver with the 4 mm bit and J0 attachment.
  2. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 2 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 2 단계, 이미지 2/2
    • Remove the top piece and the washers held under the middle screw.
  3. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 3 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 3 단계, 이미지 2/2
    • Pull the eyepieces off the binoculars.
  4. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 4 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 4 단계, 이미지 2/2
    • Remove the two side J0 head screws.
  5. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 5 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 5 단계, 이미지 2/2
    • Remove the four J0 head eyepiece screws.
  6. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 6 단계, 이미지 1/1
    • Remove the two eyepiece plates.
  7. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 7 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 7 단계, 이미지 2/2
    • Pry apart the rear rubber covering on each side to expose the two back prism adjustment screws.
  8. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 8 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 8 단계, 이미지 2/2
    • Adjust the two 1.5 mm flat head prism screws by slightly turning the driver.
    • Note: Look through the binoculars after each turn, and if the vision is aligned, you can stop at this step. If adjusting these screws does not align the vision, proceed to Step 9.
    • DO NOT tighten the prism screws too much, or you will crack the prism and permanently destroy it. Repairing or replacing the prism is beyond the scope of this guide.
  9. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 9 단계, 이미지 1/1
    • Unscrew the two front objective lenses by hand.
  10. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 10 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 10 단계, 이미지 2/2
    • Unscrew the two J0 head front screws.
  11. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 11 단계, 이미지 1/1
    • Remove the two front plates.
  12. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 12 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 12 단계, 이미지 2/2
    • Peel back the front rubber coverings on both sides.
  13. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 13 단계, 이미지 1/2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: 13 단계, 이미지 2/2
    • Adjust the two front 1.5 mm flat head prism screws with small turns.
    • Look through the binoculars after each adjustment to see if it is aligning the vision, and repeat the adjustments until it is repaired.
    • You may need to return to Step 8 to fine-tune the other set of screws. All four prism adjustment screws must be in their correct positions to produce the correct view through the binoculars.
결론
다른 3명이 해당 안내서를 완성하였습니다.
James Silva
회원 가입일: 09/30/19
235 평판
안내서 1개 작성함
CSU Fullerton, Team S1-G3, Bruce Fall 2019 CSU Fullerton, Team S1-G3, Bruce Fall 2019 회원
CSUF-BRUCE-F19S1G3
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 45
30일 전: 197
전체 시간: 4,281
