주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair Dried Out Liquid Lipstick
필요한 것
  1. How to Repair Dried Out Liquid Lipstick, How to Repair Dried Out Liquid Lipstick: 1 단계, 이미지 1개 중 1개
    • Fill a bowl full of warm to hot water and place off to the side for later.
    댓글 쓰기
  2. How to Repair Dried Out Liquid Lipstick: 2 단계, 이미지 1개 중 1개
    • Tighten the cap on the liquid lipstick to prevent water from going inside while the lipstick is submerged in the bowl of water.
    댓글 쓰기
  3. How to Repair Dried Out Liquid Lipstick: 3 단계, 이미지 1개 중 1개
    • Take one pipe cleaner and wrap it all the way around the seal of the liquid lipstick cap to help prevent water from entering the lipstick.
    • Wrap a second pipe cleaner one to two times around the first pipe cleaner.
    • Make sure you leave enough length on either side of the pipe cleaner so that it can hang onto the sides of the bowl.
    댓글 쓰기
  4. How to Repair Dried Out Liquid Lipstick: 4 단계, 이미지 1개 중 1개
    • Submerge the liquid lipstick into the warm water.
    • Make sure both ends of the pipe cleaner are leaning on the sides of the bowl to keep the liquid lipstick upright in the water.
    • Leave the liquid lipstick in the water for 25-30 minutes.
    댓글 쓰기
  5. How to Repair Dried Out Liquid Lipstick: 5 단계, 이미지 1개 중 1개
    • After the 25-30 minutes are up, remove the liquid lipstick.
    • Shake the liquid lipstick tube to make sure the lipstick has liquified again or you can take the wand and mix it around inside of the tube instead.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tamisha Green
회원 가입일: 11/16/21
148 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 54
전체 시간: 1,592
