주요 콘텐츠로 건너뛰기
How to Repair Frayed Shoelaces
필요한 것
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: 1 단계, 이미지 1개 중 1개
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: 2 단계, 이미지 3개 중 1개 How to Repair Frayed Shoelaces: 2 단계, 이미지 3개 중 2개 How to Repair Frayed Shoelaces: 2 단계, 이미지 3개 중 3개
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: 3 단계, 이미지 2개 중 1개 How to Repair Frayed Shoelaces: 3 단계, 이미지 2개 중 2개
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: 4 단계, 이미지 3개 중 1개 How to Repair Frayed Shoelaces: 4 단계, 이미지 3개 중 2개 How to Repair Frayed Shoelaces: 4 단계, 이미지 3개 중 3개
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: 5 단계, 이미지 1개 중 1개
    • Repeat these steps on all the other frayed shoelaces.
결론
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Anirudh Jain
회원 가입일: 04/09/15
605 평판
안내서 1개를 작성함
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 회원
CPSU-GREEN-S15S28G6
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 31
전체 시간: 12,472
