소개
GPS signal repair
필요한 것
동영상 지침
결론
다른 한 분이 해당 안내서를 완성하였습니다.
GPS signal repair
지난 24시간: 5
지난 7일: 24
지난 30일: 60
전체 시간: 2,181
1가이드 댓글
Hi sir, i have the exact same problem with GPS. At first i thought it’s a software problem so i tried every way i could find on the internet but none of them seem to work.
I read so many Zenfone user using your method solve the problem. I’d like to try it as well hoping my GPS will fixed.
My question is :
the GPS antenna separated in two parts which connected to two connectors. As i see the pics in your vid, do i have to connect only the upper part of antenna to the upper connector? and is it necessary to put the other end of cooper wire to the small hole below the sim card slot?
Any answer will be much appreciated.
Thank you from Bali
Vickkal Kristianes - 답글 공유
