주요 콘텐츠로 건너뛰기
How to Repair GPS
필요한 것
동영상 지침
결론
marekaureliuszszulc
회원 가입일: 04/06/17
131 평판
안내서 1개 작성함
댓글 한 개
Hi sir, i have the exact same problem with GPS. At first i thought it’s a software problem so i tried every way i could find on the internet but none of them seem to work.
I read so many Zenfone user using your method solve the problem. I’d like to try it as well hoping my GPS will fixed.
My question is :
the GPS antenna separated in two parts which connected to two connectors. As i see the pics in your vid, do i have to connect only the upper part of antenna to the upper connector? and is it necessary to put the other end of cooper wire to the small hole below the sim card slot?
Any answer will be much appreciated.
Thank you from Bali
Vickkal Kristianes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,923
