주요 콘텐츠로 건너뛰기
How to Repair LP Record Playing Surface
필요한 것
  1. How to Repair LP Record Playing Surface, How to Repair LP Record Playing Surface: 1 단계, 이미지 1개 중 1개
    • Create a solution of 2 parts water to 1 part rubbing alcohol.
    • Using a paper towel, lightly brush the record with this solution.
  2. How to Repair LP Record Playing Surface: 2 단계, 이미지 1개 중 1개
    • Apply enough wood glue to cover the record's surface.
  3. How to Repair LP Record Playing Surface: 3 단계, 이미지 1개 중 1개
    • Place the record on a record player, then turn on the record player so it rotates.
    • With a note card, apply the wood glue so that it covers the entire record surface.
    • Avoid getting glue on the record's label, as this will damage the label once the glue dries.
  4. How to Repair LP Record Playing Surface: 4 단계, 이미지 1개 중 1개
    • Place a strip of tape on the wet wood glue.
    • This will act as a handle later to remove the dried wood glue.
  5. How to Repair LP Record Playing Surface: 5 단계, 이미지 1개 중 1개
    • Turn the record player off after you apply the wood glue.
    • Let the record sit for 12 hours to dry.
  6. How to Repair LP Record Playing Surface: 6 단계, 이미지 1개 중 1개
    • After 12 hours, check to see the wood glue has dried.
    • If it has dried, use the tape as a “handle” to peel the glue off.
    • If the wood glue is not yet dry, check back once every hour until it has dried.
  7. How to Repair LP Record Playing Surface: 7 단계, 이미지 1개 중 1개
    • Repeat steps 1-6 on the opposite side of the LP if necessary.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Connor Enos
회원 가입일: 07/03/18
205 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 42
전체 시간: 2,443
