주요 콘텐츠로 건너뛰기
How to Repair Loose Joints in Gunpla Figures
필요한 것
  1. How to Repair Loose Joints in Gunpla Figures, How to Repair Loose Joints in Gunpla Figures: 1 단계, 이미지 1/1
    • With any model you own, find the loose part. It can be the head or arm moving too loosely or a part of the arm or leg that falls off too much.
    • While the model you use may differ from the one in the guide, the joints shown are similar to those used in most models.
    • Before you do this, if you plan on adding paint to your model, do it before applying glue to your joints.
  2. How to Repair Loose Joints in Gunpla Figures: 2 단계, 이미지 1/2 How to Repair Loose Joints in Gunpla Figures: 2 단계, 이미지 2/2
    • If you have a loose arm, you’ll have to take it apart to access the areas where you need to apply glue.
    • Using a bamboo stick (or any stick), apply super glue to the tip to spread it evenly against the ball or peg joint.
    • After you finish, wait for it to dry before you connect any parts to it.
    • When the super glue dries up, it may leave white marks. This means there's too much glue, so try not to apply too much.
    • If you get glue on your fingers, apply soap and warm water to them. This will cause the glue to be easier to remove.
  3. How to Repair Loose Joints in Gunpla Figures: 3 단계, 이미지 1/3 How to Repair Loose Joints in Gunpla Figures: 3 단계, 이미지 2/3 How to Repair Loose Joints in Gunpla Figures: 3 단계, 이미지 3/3
    • Make sure to add a small layer of glue to the peg joint and spread it evenly around the peg area.
    • DO NOT add glue inside the part that the peg connects to. It may cause the peg to have less movement.
    • Once it's dried, reassemble the arm back together.
  4. How to Repair Loose Joints in Gunpla Figures: 4 단계, 이미지 1/3 How to Repair Loose Joints in Gunpla Figures: 4 단계, 이미지 2/3 How to Repair Loose Joints in Gunpla Figures: 4 단계, 이미지 3/3
    • Detach the legs from the waist and disassemble them to access the ball joint.
    • Apply a small amount of glue to the ball joint and spread it evenly.
    • If you apply too much glue, it can cause damage to the ball joint.
    • Once it's dry, reattach the legs and reassemble the waist. Start to move the joint around to see how it feels.
  5. How to Repair Loose Joints in Gunpla Figures: 5 단계, 이미지 1/2 How to Repair Loose Joints in Gunpla Figures: 5 단계, 이미지 2/2
    • For the head, you’ll need to remove it to expose the joint.
    • Apply a small amount of glue to it and spread it evenly.
    • Once it's dry, reattach the head to the joint and move it around to see how it feels.
결론
Once you're done reassemble your model and try to move the joints around to see if you need to fix anything else.
다른 2명이 해당 안내서를 완성하였습니다.
Steven Magana
회원 가입일: 10/25/23
175 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-12, Kershman Fall 2023 CSU Los Angeles, Team 4-12, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G12
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 112
전체 시간: 708
