주요 콘텐츠로 건너뛰기
How to Repair Malfunctioning Cordless Window Blinds
필요한 것
  1. How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 1 단계, 이미지 1/3 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 1 단계, 이미지 2/3 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 1 단계, 이미지 3/3
    • Remove the clips that keep the blinds attached to the wall.
    • These should easily slide out.
  2. How to Repair Malfunctioning Cordless Window Blinds: 2 단계, 이미지 1/2 How to Repair Malfunctioning Cordless Window Blinds: 2 단계, 이미지 2/2
    • Slide the angling rod off its hook.
  3. How to Repair Malfunctioning Cordless Window Blinds: 3 단계, 이미지 1/1
    • Locate the pulley where the string exits the top housing.
    • The string has likely fallen off of the pulley, causing too much resistance for the retraction mechanism to work properly.
  4. How to Repair Malfunctioning Cordless Window Blinds: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pull the shaft partially out of the housing.
    • The shaft is not supposed to come out of the housing all of the way. This step is meant to bend the shaft just enough so that the tweezers can reach behind it.
  5. How to Repair Malfunctioning Cordless Window Blinds: 5 단계, 이미지 1/1
    • From the bottom of the housing, pull on the string that runs through the blinds.
    • This step is meant to add slack in the string.
    • Hold the slack by putting a finger through the loop it makes.
  6. How to Repair Malfunctioning Cordless Window Blinds: 6 단계, 이미지 1/1
    • While holding the slack with your middle finger, and the shaft with your index finger, use the tweezers to grab on to the string from the top side of the housing.
    • Pull the string up and toward you as you remove your middle finger from the loop.
  7. How to Repair Malfunctioning Cordless Window Blinds: 7 단계, 이미지 1/2 How to Repair Malfunctioning Cordless Window Blinds: 7 단계, 이미지 2/2
    • Test the blinds to see if they are working. If they aren't, check to see if the string has been realigned on the pulley and repeat the steps as necessary.
결론
Enjoy your retractable blinds!
Adam Porter
회원 가입일: 02/26/22
145 평판
안내서 1개 작성함
University of Memphis, Team 51-1, Willis Spring 2022 University of Memphis, Team 51-1, Willis Spring 2022 회원
UM-WILLIS-S22S51G1
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 41
7일 전: 250
30일 전: 1,044
전체 시간: 25,099
