주요 콘텐츠로 건너뛰기
How to Repair Maytag MRT311FFFE Frozen Ventilation System
필요한 것
  1. How to Repair Maytag MRT311FFFE Frozen Ventilation System, How to Repair Maytag MRT311FFFE Frozen Ventilation System: 1 단계, 이미지 1/2 How to Repair Maytag MRT311FFFE Frozen Ventilation System, How to Repair Maytag MRT311FFFE Frozen Ventilation System: 1 단계, 이미지 2/2
    • Set the temperature switch in the refrigerator to “OFF.”
  2. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 2 단계, 이미지 1/2 How to Repair Maytag MRT311FFFE Frozen Ventilation System: 2 단계, 이미지 2/2
    • Remove all items from the freezer, including the freezer shelf.
  3. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 3 단계, 이미지 1/2 How to Repair Maytag MRT311FFFE Frozen Ventilation System: 3 단계, 이미지 2/2
    • Use a 6 mm Allen key to remove the two 6.0 mm screws securing the freezer’s interior back cover.
  4. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 4 단계, 이미지 1/1
    • Gently pull the freezer’s interior back cover and set it face down on the bottom of the freezer.
    • It won’t completely come off since there’s a cable connected to the back cover.
    • Be careful not to dislodge any wires.
  5. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 5 단계, 이미지 1/1
    • Check the ventilator’s compartment for frozen blockages.
    • You can use a flashlight for a better look, or fish something long and thin into the compartment; if it hits something, it’s because it’s blocked with ice.
  6. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 6 단계, 이미지 1/1
    • Turn the hairdryer onto its "hot" or "warm" setting, then point it directly into the frozen ventilator’s compartments until the ice melts, clearing the vents.
    • Be careful not to overheat the surrounding plastic.
  7. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 7 단계, 이미지 1/1
    • Replace the back cover.
    • Reinstall the two 6 mm screws with a 6 mm Allen key.
    • Replace the freezer shelf.
  8. How to Repair Maytag MRT311FFFE Frozen Ventilation System: 8 단계, 이미지 1/1
    • Reorganize the items in a way that doesn’t block the vent’s airflow.
결론
Your fridge should now be able to maintain cold temperatures again!
Nicole Rivera
회원 가입일: 03/23/22
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 55
전체 시간: 1,254
