주요 콘텐츠로 건너뛰기
How to Repair Molded Baseboards
필요한 것
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: 1 단계, 이미지 1/1
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: 2 단계, 이미지 1/1
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: 3 단계, 이미지 1/2 How to Repair Molded Baseboards: 3 단계, 이미지 2/2
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: 4 단계, 이미지 1/1
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: 5 단계, 이미지 1/1
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: 6 단계, 이미지 1/1
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: 7 단계, 이미지 1/1
    • Touch-up with matching paint as needed.
결론
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
다른 2명이 해당 안내서를 완성하였습니다.
Melanie M. Alter
회원 가입일: 09/23/21
199 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 59
30일 전: 297
전체 시간: 7,611
