주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair Molded Baseboards
필요한 것
    1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: 1 단계, 이미지 1개 중 1개
      • Sand the damaged area with the 120 grit sandpaper or a sanding block.
      • Use a utility knife to smooth rougher areas if needed.
      댓글 쓰기
    2. How to Repair Molded Baseboards: 2 단계, 이미지 1개 중 1개
      • Lightly coat the damaged area with wood glue.
      댓글 쓰기
    3. How to Repair Molded Baseboards: 3 단계, 이미지 2개 중 1개 How to Repair Molded Baseboards: 3 단계, 이미지 2개 중 2개
      • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
      • Allow to dry a few hours or overnight (based on product directions).
      댓글 쓰기
    4. How to Repair Molded Baseboards: 4 단계, 이미지 1개 중 1개
      • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
      댓글 쓰기
    5. How to Repair Molded Baseboards: 5 단계, 이미지 1개 중 1개
      • Sand the dried wood filler with 150 grit sandpaper.
      • Start from the inside of the baseboard and move out toward the repaired area.
      • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
      댓글 쓰기
    6. How to Repair Molded Baseboards: 6 단계, 이미지 1개 중 1개
      • Wipe with a slightly damp cloth.
      • Repeat step 3 as needed.
      • Wait at least one hour.
      • Repeat step 6 for the final sanding.
      댓글 쓰기
    7. How to Repair Molded Baseboards: 7 단계, 이미지 1개 중 1개
      • Touch-up with matching paint as needed.
      댓글 쓰기
결론
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Melanie M. Alter
회원 가입일: 09/23/21
199 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 40
지난 30일: 186
전체 시간: 12,058
