주요 콘텐츠로 건너뛰기
How to Repair Nylon Shorts
필요한 것
  1. How to Repair Nylon Shorts, How to Repair Nylon Shorts: 1 단계, 이미지 1/1
    • Be sure to choose a thread color that is similar to the garment you are repairing.
    • Thread the needle by stringing the thread through the eye of the needle.
    • Knot the end of the thread and cut off any excess thread. The knot should be large enough to catch the fabric and not pull through.
  2. How to Repair Nylon Shorts: 2 단계, 이미지 1/1
    • Take the torn seam into both hands, and overlap one side with the other until both sides are aligned.
  3. How to Repair Nylon Shorts: 3 단계, 이미지 1/1
    • Starting from the inside of the garment, pull the needle through the fabric.
    • Pull the thread until the knot catches the fabric.
  4. How to Repair Nylon Shorts: 4 단계, 이미지 1/1
    • Make small stitches along the length of the rip.
    • Do not pull the thread too tight or it will cause rippling in the fabric.
  5. How to Repair Nylon Shorts: 5 단계, 이미지 1/1
    • Tie the thread as close to the fabric as possible.
    • Cut off any extra thread that is still attached.
결론
This guide can be applied to any piece of clothing that has a rip in the seam. Happy stitching!
다른 한 분이 해당 안내서를 완성하였습니다.
Rachel Brockett
회원 가입일: 10/12/18
145 평판
안내서 1개 작성함
Missouri Western, Team S1-G1, Cools Stephens Fall 2018 Missouri Western, Team S1-G1, Cools Stephens Fall 2018 회원
MWSU-COOLS STEPHENS-F18S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 65
전체 시간: 2,343
