이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This shouldn't take more than 15 minutes, if you know how to use a needle and thread. However, it may take a bit longer if you have never used a needle and thread.
필요한 것
White thread and needle. String white thread through the eye of the needle, and pull through. Knot the string between the two ends, until knot is large enough to catch on the cloth.
Fabric should be easy to move around in, with no cinches.
다른 한 분이 해당 안내서를 완성하였습니다.
