주요 콘텐츠로 건너뛰기
How to Repair Scratches in Laminate Finish Furniture
필요한 것
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: 1 단계, 이미지 1개 중 1개
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: 2 단계, 이미지 1개 중 1개
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: 3 단계, 이미지 1개 중 1개
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: 4 단계, 이미지 1개 중 1개
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: 5 단계, 이미지 1개 중 1개
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: 6 단계, 이미지 1개 중 1개
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: 7 단계, 이미지 1개 중 1개
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
결승점
작성자
1다른 기여자 명과 함께
Shelby
회원 가입일: 02/20/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 100
전체 시간: 1,084
