주요 콘텐츠로 건너뛰기
How to Repair Timex t121b Buttons
필요한 것
  1. How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 1 단계, 이미지 3개 중 1개 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 1 단계, 이미지 3개 중 2개 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 1 단계, 이미지 3개 중 3개
    • Unplug the alarm clock from the power.
    • Flip the alarm clock upside down and open the lid.
    • Take out the batteries and leave them aside.
  2. How to Repair Timex t121b Buttons: 2 단계, 이미지 3개 중 1개 How to Repair Timex t121b Buttons: 2 단계, 이미지 3개 중 2개 How to Repair Timex t121b Buttons: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove all of the screws on the underside of the clock.
    • Carefully lift the cover and lay it down as shown in the third image.
  3. How to Repair Timex t121b Buttons: 3 단계, 이미지 3개 중 1개 How to Repair Timex t121b Buttons: 3 단계, 이미지 3개 중 2개 How to Repair Timex t121b Buttons: 3 단계, 이미지 3개 중 3개
    • Flip the alarm clock until the top of the clock is facing down.
    • Take out the first screw (1.2 mm Phillips) as shown in the second image.
    • Take out the second screw (1.2 mm Phillips) as shown in the third image.
  4. How to Repair Timex t121b Buttons: 4 단계, 이미지 3개 중 1개 How to Repair Timex t121b Buttons: 4 단계, 이미지 3개 중 2개 How to Repair Timex t121b Buttons: 4 단계, 이미지 3개 중 3개
    • Carefully check the buttons and make sure you are able to press all the buttons.
    • Clean any dust that might be interfering with the buttons.
    • Adjust and push the alarm slide button to its proper position as shown in the third image.
  5. How to Repair Timex t121b Buttons: 5 단계, 이미지 3개 중 1개 How to Repair Timex t121b Buttons: 5 단계, 이미지 3개 중 2개 How to Repair Timex t121b Buttons: 5 단계, 이미지 3개 중 3개
    • Put the board back in place and place the first screw (1.2 mm Phillips) as shown in the first image.
    • Place the second screw (1.2 mm Phillips) as shown in the second image.
    • Carefully place the two halves of the clock back together and put all 4 screws (1.2 mm Phillips) as shown in the third image.
    • Open the back lid and place the batteries.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jad Abdalnor
회원 가입일: 01/18/22
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 705
