주요 콘텐츠로 건너뛰기
How to Repair Trim On a Decorative Towel
필요한 것
  1. How to Repair Trim On a Decorative Towel, How to Repair Trim On a Decorative Towel: 1 단계, 이미지 1/1
    • Choose a thread the same colour as the towel.
    • Use sewing scissors to cut a piece of thread about 18 inches long.
  2. How to Repair Trim On a Decorative Towel: 2 단계, 이미지 1/1
    • Thread the string through the needle.
    • Tie a knot at the longest end of the thread.
  3. How to Repair Trim On a Decorative Towel: 3 단계, 이미지 1/2 How to Repair Trim On a Decorative Towel: 3 단계, 이미지 2/2
    • Flip your towel over so the backside of the towel is facing up.
  4. How to Repair Trim On a Decorative Towel: 4 단계, 이미지 1/2 How to Repair Trim On a Decorative Towel: 4 단계, 이미지 2/2
    • Starting at one side of the rip, insert the needle through the trim and then the towel.
    • Pull the thread through until it stops at the knot.
  5. How to Repair Trim On a Decorative Towel: 5 단계, 이미지 1/2 How to Repair Trim On a Decorative Towel: 5 단계, 이미지 2/2
    • Flip the towel over so the front side is facing up.
    • Insert the needle through the towel, then the trim.
    • Pull the thread through.
  6. How to Repair Trim On a Decorative Towel: 6 단계, 이미지 1/2 How to Repair Trim On a Decorative Towel: 6 단계, 이미지 2/2
    • Repeat steps 4 and 5 until you reach the end of the trim.
  7. How to Repair Trim On a Decorative Towel: 7 단계, 이미지 1/3 How to Repair Trim On a Decorative Towel: 7 단계, 이미지 2/3 How to Repair Trim On a Decorative Towel: 7 단계, 이미지 3/3
    • Insert the needle through the back of the towel.
    • Pull the string through with enough length to create a small loop.
    • Put the needle through the loop and pull the string to tie a knot.
  8. How to Repair Trim On a Decorative Towel: 8 단계, 이미지 1/2 How to Repair Trim On a Decorative Towel: 8 단계, 이미지 2/2
    • Remove the needle.
    • Use your sewing scissors to cut the remaining thread.
결론
Victoria Torkos
회원 가입일: 09/19/22
157 평판
안내서 1개 작성함
York University, Team A-3, Morris Fall 2022 York University, Team A-3, Morris Fall 2022 회원
YORK-MORRIS-F22SAG3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 262
