주요 콘텐츠로 건너뛰기
How to Repair Water Damage Under Your Sink
필요한 것
  1. How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 1 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 1 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 1 단계, 이미지 3개 중 3개
    • Remove all items from under your sink.
    • Test for water leaks by gently pressing the cabinet with your fingers and seeing if it's wet and by looking for drips from the sink.
    • Clean the cabinet using a sponge or cloth with a cleaner or disinfectant of your choice.
  2. How to Repair Water Damage Under Your Sink: 2 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink: 2 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink: 2 단계, 이미지 3개 중 3개
    • Use work gloves to sand the cabinet.
    • Use 100-grit sandpaper to sand the interior of the cabinets using a circular motion.
    • Sand until you can move your hand across the cabinet, and it feels smooth.
    • Clean the sand dust from the cabinet with a damp cloth or sponge.
  3. How to Repair Water Damage Under Your Sink: 3 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink: 3 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink: 3 단계, 이미지 3개 중 3개
    • Apply wood filler with a paint tool making sure you don't apply too much of the filler.
    • You want the layer of filler to be smooth for when you paint over it later.
    • Use painter's tape to mark the areas that you don't want paint on.
  4. How to Repair Water Damage Under Your Sink: 4 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink: 4 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink: 4 단계, 이미지 3개 중 3개
    • Use a caulking gun to seal the edges of the base. Gently press down on the applicator and follow the perimeter of the cabinet.
    • Use your finger to wipe all excess caulk off.
    • Let it dry for 30 minutes.
  5. How to Repair Water Damage Under Your Sink: 5 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink: 5 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink: 5 단계, 이미지 3개 중 3개
    • Use an angle brush to paint all the edges with primer.
    • Use a roller to paint the rest of the cabinet with primer.
    • Let it dry for 1 hour or until it is completely dry.
  6. How to Repair Water Damage Under Your Sink: 6 단계, 이미지 3개 중 1개 How to Repair Water Damage Under Your Sink: 6 단계, 이미지 3개 중 2개 How to Repair Water Damage Under Your Sink: 6 단계, 이미지 3개 중 3개
    • Use an angle brush to paint all the edges with the paint of your choice.
    • Use the roller to complete painting the cabinet.
    • Let the paint dry.
    • Place your items back under the sink.
결론
Now, you've got a good-as-new cabinet! You can reapply as needed if paint chips or dulls.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chelsea Trevino
회원 가입일: 09/24/23
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 46
지난 30일: 223
전체 시간: 3,690
