주요 콘텐츠로 건너뛰기
How to Repair Wires on Axess SPBT1031
필요한 것
  1. How to Repair Wires on Axess SPBT1031, How to Repair Wires on Axess SPBT1031: 1 단계, 이미지 1개 중 1개
    • The first and most difficult step is to locate where the damaged wire is. To locate the damaged wire, we will start in the most easy to access places first.
    • Begin by removing the two main black face plates on either end of the speaker tube using a Phillips head PH1 screwdriver fitting to remove a total of four screws.
    • 2 on top on of either end of the speaker, 2 on bottom of either end of the speaker.
  2. How to Repair Wires on Axess SPBT1031: 2 단계, 이미지 2개 중 1개 How to Repair Wires on Axess SPBT1031: 2 단계, 이미지 2개 중 2개
    • Faulty wires can usually be located by spotting physical damage to the wire itself such as: fraying, complete disconnection, or a notched appearance.
  3. How to Repair Wires on Axess SPBT1031: 3 단계, 이미지 1개 중 1개
    • If there are no signs of wire damage in these locations, then it’s time to remove the red interface plate.
    • To do this, use a metal spudger as a wedge and insert it in the center and outer edge of the two mesh pieces to remove them exposing screws.
  4. How to Repair Wires on Axess SPBT1031: 4 단계, 이미지 1개 중 1개
    • Use a PH1 size Phillips head screwdriver to remove the four 0.7 cm screws.
  5. How to Repair Wires on Axess SPBT1031: 5 단계, 이미지 1개 중 1개
    • Pull out the red interface plate to expose the wires that were previously hidden between the black faceplate and red interface plate.
    • Again look for signs of wire damage.
  6. How to Repair Wires on Axess SPBT1031: 6 단계, 이미지 1개 중 1개
    • Before progressing, you will want to be sure the power is turned off and the battery is disconnected.
    • Look into the back of the red interface plate and locate the bottom of the motherboard.
  7. How to Repair Wires on Axess SPBT1031: 7 단계, 이미지 1개 중 1개
    • On the bottom of the motherboard, locate the black and red wire pair connected to the plastic red socket and remove the white insert from this socket.
  8. How to Repair Wires on Axess SPBT1031: 8 단계, 이미지 1개 중 1개
    • To repair a wire connection, use wire strippers to cut away the wire portion until no visible damage remains.
  9. How to Repair Wires on Axess SPBT1031: 9 단계, 이미지 1개 중 1개
    • Again, use the wire strippers to strip back a small amount of the rubber coating on the wire. Therefore exposing a small amount of bare wire.
  10. How to Repair Wires on Axess SPBT1031: 10 단계, 이미지 1개 중 1개
    • Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
    • Then use a wire crimping tool to crimp the the butt connector, therefore making a solid contact connection.
    • Repeat for the loose wire into the other end of the same wire butt connector.
    • If you do not have enough wire length to spare, then secure some small gauge wire replacement to bridge the gap. If this is the case you will need at least two wire butt connectors, follow the same steps as above to crimp the wire.
결론
작성자
5다른 기여자 명과 함께
Elvira Lou Evangelista
회원 가입일: 03/09/16
957 평판
안내서 6개를 작성함
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G6
3 회원들
안내서 8개를 작성함
1가이드 댓글
Just one wire is not going to do it. A red wire
Was loose before I opened the speaker and I can't see where it was attached to. Why don't you put a pic of the circuit board so people can fix your cheap ass connections.
Juan Cardenas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 17
전체 시간: 3,618
