소개
This guide will be helpful for repairing your faulty wires if the troubleshooting page recommends that you replace them. This is a necessary step when you have determined no other way to repair your current wires. Be wary of accidentally damaging other parts of the device when replacing wires.
필요한 것
Begin by removing the two main black face plates on either end of the speaker tube using a Phillips head PH1 screwdriver fitting to remove a total of four screws.
2 on top on of either end of the speaker, 2 on bottom of either end of the speaker.
Assuming you have enough wire length to spare, insert the bare wire into a wire butt connector so it just passes the nub on one end.
Then use a wire crimping tool to crimp the the butt connector, therefore making a solid contact connection.
Repeat for the loose wire into the other end of the same wire butt connector.
댓글 한 개
Just one wire is not going to do it. A red wire
Was loose before I opened the speaker and I can't see where it was attached to. Why don't you put a pic of the circuit board so people can fix your cheap ass connections.
