주요 콘텐츠로 건너뛰기
How to Repair Your Torn Sleeping Bag
필요한 것
  1. How to Repair Your Torn  Sleeping Bag, How to Repair Your Torn  Sleeping Bag: 1 단계, 이미지 1/1
    • Push any stuffing/down filling back into the hole.
    • You can use your finger, but depending on the size of the hole you may want to use a smaller object so that it doesn't tear further.
  2. How to Repair Your Torn  Sleeping Bag: 2 단계, 이미지 1/3 How to Repair Your Torn  Sleeping Bag: 2 단계, 이미지 2/3 How to Repair Your Torn  Sleeping Bag: 2 단계, 이미지 3/3
    • Take your roll of duct tape and cut off a small amount (about as long as the tear)
  3. How to Repair Your Torn  Sleeping Bag: 3 단계, 이미지 1/1
    • Fold the edges of the tear back towards the stuffing so that you create a clean edge with no fraying.
    • This makes it easier to apply the duct tape.
  4. How to Repair Your Torn  Sleeping Bag: 4 단계, 이미지 1/1
    • Apply the duct tape to each half of the tear and fold it under, creating a cuff/edge of duct tape
    • This will allow you to sew the fabric without tearing it.
  5. How to Repair Your Torn  Sleeping Bag: 5 단계, 이미지 1/1
    • Take a small needle and thread it with thread of similar color to the sleeping bag material (can be any color but a similar one makes the fix less noticeable)
    • Working with needles can be dangerous.
  6. How to Repair Your Torn  Sleeping Bag: 6 단계, 이미지 1/3 How to Repair Your Torn  Sleeping Bag: 6 단계, 이미지 2/3 How to Repair Your Torn  Sleeping Bag: 6 단계, 이미지 3/3
    • Push the two pieces of duct tape together and use the needle and thread to sew them together with a whip stitch.
  7. How to Repair Your Torn  Sleeping Bag: 7 단계, 이미지 1/3 How to Repair Your Torn  Sleeping Bag: 7 단계, 이미지 2/3 How to Repair Your Torn  Sleeping Bag: 7 단계, 이미지 3/3
    • Pull the thread tight when you reach the end of the tape and tie a knot in the string
    • Cut off any remaining thread.
  8. How to Repair Your Torn  Sleeping Bag: 8 단계, 이미지 1/2 How to Repair Your Torn  Sleeping Bag: 8 단계, 이미지 2/2
    • Cut off any remaining duct tape.
    • Be wary of a sticky residue that may be left behind from the duct tape if pulled off to remove excess
    • Enjoy your newly patched sleeping bag!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Michelle Stovall
회원 가입일: 09/29/15
128 평판
안내서 1개 작성함
Cal Poly, Team 10-4, Green Fall 2015 Cal Poly, Team 10-4, Green Fall 2015 회원
CPSU-GREEN-F15S10G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 26
전체 시간: 6,150
