주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Backward-Tilted Porch Swing
필요한 것
    1. How to Repair a Backward-Tilted Porch Swing, How to Repair a Backward-Tilted Porch Swing: 1 단계, 이미지 2개 중 1개 How to Repair a Backward-Tilted Porch Swing, How to Repair a Backward-Tilted Porch Swing: 1 단계, 이미지 2개 중 2개
      • (Before) Backward-Tilted Swing
      • Examine each side of the swing to determine the hook type used for hanging (ex., S-hook, eye bolt, screw carabiner hook, or other types).
      • For this example, the hook is an S hook.
      댓글 쓰기
    2. How to Repair a Backward-Tilted Porch Swing: 2 단계, 이미지 3개 중 1개 How to Repair a Backward-Tilted Porch Swing: 2 단계, 이미지 3개 중 2개 How to Repair a Backward-Tilted Porch Swing: 2 단계, 이미지 3개 중 3개
      • Use a measuring tape to check and record the height of the swing from the ground to the armrest. Repeat this step on the other side.
      • Use a measuring tape to check and record the height of the swing from the ground to the top of the swing. Repeat this step on the other side.
      • Record these measurements to compare later.
      • (Optional) Place a level on the seat of the swing to check if it is level. Adjust the chains as needed until the bubble is centered.
      • Notice how the bubble is not centered to show the swing is level.
      댓글 쓰기
    3. How to Repair a Backward-Tilted Porch Swing: 3 단계, 이미지 2개 중 1개 How to Repair a Backward-Tilted Porch Swing: 3 단계, 이미지 2개 중 2개
      • Use one pair of pliers to hold the S-hook steady.
      • Use the second pair of pliers to gently open the bottom side of the hook, allowing the chain links to slide off. This provides better leverage and stability.
      • For other hook types, gently open or unscrew the hook and slide the chain off without bending or damaging the hook.
      • Use caution when opening the hook to avoid injury from any sharp edges.
      • Repeat this step to open the hook on the other side of the swing.
      • There should be a noticeable difference in the openings at the top and bottom of the hook.
      댓글 쓰기
    4. How to Repair a Backward-Tilted Porch Swing: 4 단계, 이미지 2개 중 1개 How to Repair a Backward-Tilted Porch Swing: 4 단계, 이미지 2개 중 2개
      • Slide the chain closest to the back of the swing off the hook after opening it.
      • Other types of hooks may require different methods, but most of them should allow the chain to gently slide off.
      • Measure each link until you reach your desired position.
      • On the other side, use a marker or pencil to mark the link of the chain that will be reattached on the other side.
      • If your swing is already level horizontally, the number of links removed should match on each side.
      댓글 쓰기
    5. How to Repair a Backward-Tilted Porch Swing: 5 단계, 이미지 1개 중 1개
      • Reattach each chain to its hook.
      • Ensure that the marked link is connected to the hook on both sides.
      • Ensure that you have a firm grip on the chain to prevent it from dropping. Dropping the swing can cause injury or damage.
      • Ensure that the swing is at the desired height.
      댓글 쓰기
    6. How to Repair a Backward-Tilted Porch Swing: 6 단계, 이미지 3개 중 1개 How to Repair a Backward-Tilted Porch Swing: 6 단계, 이미지 3개 중 2개 How to Repair a Backward-Tilted Porch Swing: 6 단계, 이미지 3개 중 3개
      • Compare previous measurements to new measurements to ensure they are consistent on both sides. This is crucial to a level swing.
      • (Optional) Place a level on the armrest of the swing to check if it is level.
      • The bubbles are resting between the two lines, indicating that the swing is level.
      • (Optional) If there are still excess links, use bolt cutters to snip them off. Repeat this on both sides, if necessary.
      • Be careful when using bolt cutters to prevent injury.
      댓글 쓰기
    7. How to Repair a Backward-Tilted Porch Swing: 7 단계, 이미지 1개 중 1개
      • Use pliers to gently squeeze the opening of the S-hook closed to secure the chain in place.
      • Other hooks may not require pliers to tighten the hook.
      • Be cautious not to apply too much pressure, as this could bend the hook or damage the chain.
      댓글 쓰기
    8. How to Repair a Backward-Tilted Porch Swing: 8 단계, 이미지 1개 중 1개
      • Give the swing a gentle push to ensure that it swings freely and is stable after adjustments on both sides.
      • (After) Level Swing
      댓글 쓰기
결론
Test your swing out by sitting in it. If the swing is still not in the desired position, repeat these steps to reposition it. Remember to check your swing regularly to keep it in good working condition!
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Hannah Myrick
회원 가입일: 03/19/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 92
전체 시간: 601
