주요 콘텐츠로 건너뛰기
How to Repair a Bra Underwire
필요한 것
  1. How to Repair a Bra Underwire, How to Repair a Bra Underwire: 1 단계, 이미지 1개 중 1개
    • Locate the problem: find where the underwire breaks through the fabric of the bra.
  2. How to Repair a Bra Underwire: 2 단계, 이미지 2개 중 1개 How to Repair a Bra Underwire: 2 단계, 이미지 2개 중 2개
    • Push the underwire back into the fabric of the side of the cup.
    • When back in place, the wire should not be visible.
  3. How to Repair a Bra Underwire: 3 단계, 이미지 1개 중 1개
    • Take a piece of matching scrap fabric and cut to the appropriate size.
    • Make sure the fabric is a bit bigger than the wire's puncture hole.
    • If the fabric is too thin, you can fold it to create a thicker piece.
  4. How to Repair a Bra Underwire: 4 단계, 이미지 3개 중 1개 How to Repair a Bra Underwire: 4 단계, 이미지 3개 중 2개 How to Repair a Bra Underwire: 4 단계, 이미지 3개 중 3개
    • Measure the appropriate length of thread and cut it.
    • Thread the needle and pull both ends evenly to double up the thread.
    • Tie the two loose ends of the thread together with a simple knot.
  5. How to Repair a Bra Underwire: 5 단계, 이미지 2개 중 1개 How to Repair a Bra Underwire: 5 단계, 이미지 2개 중 2개
    • Place the fabric over the hole. Sew along the perimeter of the fabric square with a simple overlock stitch.
    • An overlock stitch is a sewing technique where the edges of one or more pieces of fabric are sewn together. Watch a short video to learn how to sew the overlock stitch by hand.
    • Make sure to sew through only the patch fabric and the bra's inner fabric layer. The thread should not show at the front of the bra!
  6. How to Repair a Bra Underwire: 6 단계, 이미지 3개 중 1개 How to Repair a Bra Underwire: 6 단계, 이미지 3개 중 2개 How to Repair a Bra Underwire: 6 단계, 이미지 3개 중 3개
    • In the last stitch, leave a loop of tread and pull the needle through the loop.
    • Finish by tying a knot in the end of the tread.
    • Cut the excess thread close to the fabric.
    • Do not cut the thread too close to the knot. This will make the stitches unravel.
  7. How to Repair a Bra Underwire: 7 단계, 이미지 2개 중 1개 How to Repair a Bra Underwire: 7 단계, 이미지 2개 중 2개
    • Cut the excess fabric off the finished patch.
    • Inspect the patch to make sure it is securely sewed on the bra.
    • The final product should be a small patch on the inside of the cup.
  8. How to Repair a Bra Underwire: 8 단계, 이미지 1개 중 1개
    • No damage or evidence of sewing is shown on the outside of the bra.
    • Try on the final product to ensure correct fit and comfort.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Celeste Stoker
회원 가입일: 04/28/17
213 평판
안내서 1개를 작성함
UC Davis, Team S4-G2, Cole Spring 2017 UC Davis, Team S4-G2, Cole Spring 2017 회원
UCD-COLE-S17S4G2
3 회원들
안내서 1개 작성
2가이드 댓글
You made something that is a total pain in the #$@ not so painful anymore and thanks for adding the video cause that helped a lot
Willow Reignes - 답글
I agree with Wllow. Thank you on behalf of my wife and wallet.
Daniel Pollard - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 45
전체 시간: 9,464
