주요 콘텐츠로 건너뛰기
How to Repair a Broken Cabinet
필요한 것
  1. How to Repair a Broken Cabinet, How to Repair a Broken Cabinet: 1 단계, 이미지 1/1
    • This is the broken dresser drawer, duct tape & 5 minute 2 part wood epoxy.
  2. How to Repair a Broken Cabinet: 2 단계, 이미지 1/2 How to Repair a Broken Cabinet: 2 단계, 이미지 2/2
    • Take a piece of duct tape and put it on both sides for extra bonding support. Only put the tape on the bigger part of the dresser door for now. You will attach the other side with tape in a later step.
  3. How to Repair a Broken Cabinet: 3 단계, 이미지 1/3 How to Repair a Broken Cabinet: 3 단계, 이미지 2/3 How to Repair a Broken Cabinet: 3 단계, 이미지 3/3
    • This is a 5 minute quick setting 2 part wood epoxy. Take the top off the epoxy. Connect the syringe tip and lock it in place. Press the plunger so you can fill the needle tip with epoxy.
  4. How to Repair a Broken Cabinet: 4 단계, 이미지 1/3 How to Repair a Broken Cabinet: 4 단계, 이미지 2/3 How to Repair a Broken Cabinet: 4 단계, 이미지 3/3
    • Run a thick bead of epoxy on the inside rim of the cabinet from one end to the other.
  5. How to Repair a Broken Cabinet: 5 단계, 이미지 1/1
    • Run a thick bead of epoxy on the inside rim of the smaller piece of cabinet door.
  6. How to Repair a Broken Cabinet: 6 단계, 이미지 1/3 How to Repair a Broken Cabinet: 6 단계, 이미지 2/3 How to Repair a Broken Cabinet: 6 단계, 이미지 3/3
    • Attach and align the smaller cabinet door section to the bigger cabinet door section. Press them firmly together and apply the duct tape on both ends for bonding support.
  7. How to Repair a Broken Cabinet: 7 단계, 이미지 1/3 How to Repair a Broken Cabinet: 7 단계, 이미지 2/3 How to Repair a Broken Cabinet: 7 단계, 이미지 3/3
    • Flip door over to front side and tape both ends of the cabinet. This will add more support while it is drying.
  8. How to Repair a Broken Cabinet: 8 단계, 이미지 1/3 How to Repair a Broken Cabinet: 8 단계, 이미지 2/3 How to Repair a Broken Cabinet: 8 단계, 이미지 3/3
    • After at least 15 minutes you can pull tape off completely and wipe away any excess epoxy. It is now finished and ready to be re-installed back to the cabinet.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Calvesta Walk
회원 가입일: 02/07/16
254 평판
안내서 1개 작성함
Pasco Hernando, Team 5-8, Prince Winter 2016 Pasco Hernando, Team 5-8, Prince Winter 2016 회원
PHSC-PRINCE-W16S5G8
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Lifesaver brother!
Doug Gray - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 75
30일 전: 289
전체 시간: 23,108
