주요 콘텐츠로 건너뛰기
How to Repair a Broken Drawstring Tunnel in a Backpack
필요한 것
  1. How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 1 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 1 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Identify the repair area: 1 단계, 이미지 3개 중 3개
    • Identify the defective area and assess how large the damage is.
  2. How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 2 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 2 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Clean the area: 2 단계, 이미지 3개 중 3개
    • Cut away any damaged threads around the drawstring tunnel, to create a clean surface to repair.
  3. How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 3 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 3 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Prepare the drawstring: 3 단계, 이미지 3개 중 3개
    • Place the drawstring inside the tunnel.
    • Turn the edges inside, so that the drawstring is tucked inside.
  4. How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 4 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 4 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Pin the area: 4 단계, 이미지 3개 중 3개
    • Pin the folded parts of the tunnel securely in place and prepare the sewing machine.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Depress the sewing machine foot and remove any pins in the way of the sewing route.
  5. How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 5 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 5 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Sew the repair: 5 단계, 이미지 3개 중 3개
    • Start sewing a straight line from one side to the other and add a lock stitch at the beginning and the end.
    • Finish the sewing and cut the loose thread to make a neat finish.
  6. How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 1개 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 2개 How to Repair a Broken Drawstring Tunnel in a Backpack, Finished and ready!: 6 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 40
전체 시간: 430
