주요 콘텐츠로 건너뛰기
How to Repair a Broken Huggie Earring Clasp
필요한 것
  1. How to Repair a Broken Huggie Earring Clasp, How to Repair a Broken Huggie Earring Clasp: 1 단계, 이미지 1/1
    • Clean the post and clasp of the earring with a dry cloth.
  2. How to Repair a Broken Huggie Earring Clasp: 2 단계, 이미지 1/2 How to Repair a Broken Huggie Earring Clasp: 2 단계, 이미지 2/2
    • Close the earring and note where the main post hits the notch on the opposite side.
    • There are two notches, one on the main post and one on the opposite side of the earring.
  3. How to Repair a Broken Huggie Earring Clasp: 3 단계, 이미지 1/1
    • Mark this spot with a writing instrument (optional).
  4. How to Repair a Broken Huggie Earring Clasp: 4 단계, 이미지 1/1
    • Re-open the earring.
  5. How to Repair a Broken Huggie Earring Clasp: 5 단계, 이미지 1/3 How to Repair a Broken Huggie Earring Clasp: 5 단계, 이미지 2/3 How to Repair a Broken Huggie Earring Clasp: 5 단계, 이미지 3/3
    • Ensure the post is lined up with the opposite notch. If not, gently bend it with your finger until it is in a suitable position.
  6. How to Repair a Broken Huggie Earring Clasp: 6 단계, 이미지 1/1
    • Grip the earring post with a small plier or tweezer and push the post slightly upward.
  7. How to Repair a Broken Huggie Earring Clasp: 7 단계, 이미지 1/2 How to Repair a Broken Huggie Earring Clasp: 7 단계, 이미지 2/2
    • Open to check if the earring clicks.
  8. How to Repair a Broken Huggie Earring Clasp: 8 단계, 이미지 1/1
    • If the earring isn’t clicking, push the post further upward using pliers.
    • Adjust, then check again.
  9. How to Repair a Broken Huggie Earring Clasp: 9 단계, 이미지 1/1
    • If the earring clicks but is hard to open, push the post downward using pliers.
    • This is an adjustment process, so make small adjustments until it is restored.
  10. How to Repair a Broken Huggie Earring Clasp: 10 단계, 이미지 1/1
    • Make final adjustments until the huggie clasp clicks and the earring closes securely.
    • Wipe the marker off of your earring.
결론
Your earring is now fixed! If the post bends again, repeat the same steps to repair.
Hana Ito
회원 가입일: 04/26/24
181 평판
안내서 1개 작성함
UC Davis, Team 4-6, Whithaus Spring 2024 UC Davis, Team 4-6, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S4G6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 18
전체 시간: 58
