주요 콘텐츠로 건너뛰기
How to Repair a Broken Slider on a Suitcase Zipper
필요한 것
  1. How to Repair a Broken Slider on a Suitcase Zipper, Slider on a Zipper: 1 단계, 이미지 1개 중 1개
    • Locate the zipper with the broken slider on the suitcase.
  2. How to Repair a Broken Slider on a Suitcase Zipper: 2 단계, 이미지 2개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 2 단계, 이미지 2개 중 2개
    • Find the top of the zipper and locate the two stop pieces.
  3. How to Repair a Broken Slider on a Suitcase Zipper: 3 단계, 이미지 2개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 3 단계, 이미지 2개 중 2개
    • Use your pliers to remove both of the stop pieces from the zipper.
    • Be careful to not tear the zipper fabric when removing the stop pieces.
  4. How to Repair a Broken Slider on a Suitcase Zipper: 4 단계, 이미지 3개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 4 단계, 이미지 3개 중 2개 How to Repair a Broken Slider on a Suitcase Zipper: 4 단계, 이미지 3개 중 3개
    • Remove the original slider from the zipper.
  5. How to Repair a Broken Slider on a Suitcase Zipper: 5 단계, 이미지 2개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 5 단계, 이미지 2개 중 2개
    • Attach the new slider to the zipper.
    • You may need to use some force to get the new zipper slider onto the zipper itself.
  6. How to Repair a Broken Slider on a Suitcase Zipper: 6 단계, 이미지 3개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 6 단계, 이미지 3개 중 2개 How to Repair a Broken Slider on a Suitcase Zipper: 6 단계, 이미지 3개 중 3개
    • Attach two new stop pieces with a pair of pliers.
    • Use the pliers to crimp the stop pieces into the fabric.
    • The best area to place the stop pieces is directly above the first few teeth of the zipper.
  7. How to Repair a Broken Slider on a Suitcase Zipper: 7 단계, 이미지 2개 중 1개 How to Repair a Broken Slider on a Suitcase Zipper: 7 단계, 이미지 2개 중 2개
    • Check to make sure the zipper works by moving the slider up and down.
결승점
작성자
1다른 기여자 명과 함께
Demetria
회원 가입일: 03/07/19
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 1,830
