주요 콘텐츠로 건너뛰기
How to Repair a Broken/Cracked Soccer Shin Pad
필요한 것
  1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: 1 단계, 이미지 1/3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: 1 단계, 이미지 2/3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: 1 단계, 이미지 3/3
    • Start by properly cleaning the dirt off the soccer shin pad with a coarse brush.
    • Be sure to clear any dust from inside the crack as well, as any dirt left inside can interfere with the bonding agent
  2. How to Repair a Broken/Cracked Soccer Shin Pad: 2 단계, 이미지 1/1
    • Put one clamp on either side of the crack.
  3. How to Repair a Broken/Cracked Soccer Shin Pad: 3 단계, 이미지 1/1
    • Align the clamps so that there are no spaces throughout the crack.
  4. How to Repair a Broken/Cracked Soccer Shin Pad: 4 단계, 이미지 1/2 How to Repair a Broken/Cracked Soccer Shin Pad: 4 단계, 이미지 2/2
    • Make sure clamps are aligned with the crack before you apply the resin solution
    • Apply the resin solution onto the crack, being sure to fully cover the crack on both sides.
    • Let the solution dry for at least 30 minutes.
    • But we suggest leaving the shin pad out for 24 hours for best results.
  5. How to Repair a Broken/Cracked Soccer Shin Pad: 5 단계, 이미지 1/3 How to Repair a Broken/Cracked Soccer Shin Pad: 5 단계, 이미지 2/3 How to Repair a Broken/Cracked Soccer Shin Pad: 5 단계, 이미지 3/3
    • Remove the clamps slowly so that no damage will be done to the shin pad.
  6. How to Repair a Broken/Cracked Soccer Shin Pad: 6 단계, 이미지 1/2 How to Repair a Broken/Cracked Soccer Shin Pad: 6 단계, 이미지 2/2
    • Clean the extra resin solution that sits on top of the shin pad.
    • Your shin pad is now ready to use.
결승점
Anita Agustsdottir
회원 가입일: 01/30/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 292
