주요 콘텐츠로 건너뛰기
How to Repair a Burnt Pan
필요한 것
  1. How to Repair a Burnt Pan, How to Repair a Burnt Pan: 1 단계, 이미지 2개 중 1개 How to Repair a Burnt Pan, How to Repair a Burnt Pan: 1 단계, 이미지 2개 중 2개
    • Rinse the dirty pan with hot water.
  2. How to Repair a Burnt Pan: 2 단계, 이미지 2개 중 1개 How to Repair a Burnt Pan: 2 단계, 이미지 2개 중 2개
    • Grab a dishwasher tab and gently scrub the pan under warm water.
  3. How to Repair a Burnt Pan: 3 단계, 이미지 1개 중 1개
    • Scrub until the food debris lifts.
    • The warm water will gradually dissolve the tab as you scrub and help the tablet keep its shape rather than crumble immediately between your fingers.
  4. How to Repair a Burnt Pan: 4 단계, 이미지 2개 중 1개 How to Repair a Burnt Pan: 4 단계, 이미지 2개 중 2개
    • Rinse the pan with hot water and drain.
  5. How to Repair a Burnt Pan: 5 단계, 이미지 1개 중 1개
    • Use a sponge, brush, or scouring pad to scrub away the loosened burnt-on food.
  6. How to Repair a Burnt Pan: 6 단계, 이미지 2개 중 1개 How to Repair a Burnt Pan: 6 단계, 이미지 2개 중 2개
    • Repeat steps 4 & 5, if needed, for any stubborn spots.
  7. How to Repair a Burnt Pan: 7 단계, 이미지 2개 중 1개 How to Repair a Burnt Pan: 7 단계, 이미지 2개 중 2개
    • Before and after look of the pan.
결론
As we all cook at home, there are times when we accidentally burn the pan, especially when using a stainless steel pan instead of a nonstick one, for instance, while frying an egg or making caramel. Most of us have tried various cleaning methods. Combining personal experience with online resources, this method has proven to be the most effective and cost-friendly.
작성자
1다른 기여자 명과 함께
Trinh Nguyen
회원 가입일: 04/26/24
145 평판
안내서 1개를 작성함
UC Davis, Team 2-8, Whithaus Spring 2024 UC Davis, Team 2-8, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G8
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 377
