주요 콘텐츠로 건너뛰기
How to Repair a Burnt Wire for a Light Globe
필요한 것
  1. How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: 1 단계, 이미지 2개 중 1개 How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: 1 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to remove the two 3 mm screws from the power adapter.
  2. How to Repair a Burnt Wire for a Light Globe: 2 단계, 이미지 1개 중 1개
    • If needed, clean the power adapter's shell as much as possible.
  3. How to Repair a Burnt Wire for a Light Globe: 3 단계, 이미지 1개 중 1개
    • Use wire cutters to cut the wires to equal lengths.
  4. How to Repair a Burnt Wire for a Light Globe: 4 단계, 이미지 1개 중 1개
    • Use wire strippers to carefully peel the wire cord to expose 2 cm of wire.
  5. How to Repair a Burnt Wire for a Light Globe: 5 단계, 이미지 1개 중 1개
    • Slide the shell back into the wire cord, past the exposed copper wires.
  6. How to Repair a Burnt Wire for a Light Globe: 6 단계, 이미지 3개 중 1개 How to Repair a Burnt Wire for a Light Globe: 6 단계, 이미지 3개 중 2개 How to Repair a Burnt Wire for a Light Globe: 6 단계, 이미지 3개 중 3개
    • Grab the terminal of the power adapter and loosen the 3 mm screws of the terminal if needed.
    • Wrap one exposed copper wire around one loosened 3 mm screw and tighten the screw immediately.
    • Repeat the second bullet point for the second copper wire.
  7. How to Repair a Burnt Wire for a Light Globe: 7 단계, 이미지 2개 중 1개 How to Repair a Burnt Wire for a Light Globe: 7 단계, 이미지 2개 중 2개
    • Push the shell back into the terminal so that the terminal is protected by the shell.
    • Grab the 3 mm screws that were taken out in the first step and re-screw them into the shell.
  8. How to Repair a Burnt Wire for a Light Globe: 8 단계, 이미지 2개 중 1개 How to Repair a Burnt Wire for a Light Globe: 8 단계, 이미지 2개 중 2개
    • Plug in the power adapter into a functioning power outlet.
    • The light globe should now successfully turn on!
결승점
작성자
1다른 기여자 명과 함께
HarpreetGill
회원 가입일: 05/11/20
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 27
전체 시간: 791
