주요 콘텐츠로 건너뛰기
How to Repair a Loose Armrest on a Camping Chair
필요한 것
  1. How to Repair a Loose Armrest on a Camping Chair, Identify the repair area: 1 단계, 이미지 1/3 How to Repair a Loose Armrest on a Camping Chair, Identify the repair area: 1 단계, 이미지 2/3 How to Repair a Loose Armrest on a Camping Chair, Identify the repair area: 1 단계, 이미지 3/3
    • Locate the joint mechanism that connects the arm to the rest of the chair.
    • In this example, the arm of the chair used to be connected by a screw that has gone missing and now there are two holes left (red circles).
  2. How to Repair a Loose Armrest on a Camping Chair, Find a replacement screw: 2 단계, 이미지 1/3 How to Repair a Loose Armrest on a Camping Chair, Find a replacement screw: 2 단계, 이미지 2/3 How to Repair a Loose Armrest on a Camping Chair, Find a replacement screw: 2 단계, 이미지 3/3
    • Use the other chair arm as an example to find the right screw size (yellow circle).
    • Using a screwdriver, remove the screw from the chair arm.
    • Set this screw aside to check the replacement part.
  3. How to Repair a Loose Armrest on a Camping Chair, Select and test the replacement: 3 단계, 이미지 1/3 How to Repair a Loose Armrest on a Camping Chair, Select and test the replacement: 3 단계, 이미지 2/3 How to Repair a Loose Armrest on a Camping Chair, Select and test the replacement: 3 단계, 이미지 3/3
    • Compare the example screw with the spare parts and choose the piece that resembles it the most.
    • Once you have selected the replacement, test it to see if it fits in the right size.
    • For the testing, introduce the screw and then try pushing it outwards (red arrow).
    • Note: The right replacement should stay in place.
  4. How to Repair a Loose Armrest on a Camping Chair, Screw on the replacement: 4 단계, 이미지 1/3 How to Repair a Loose Armrest on a Camping Chair, Screw on the replacement: 4 단계, 이미지 2/3 How to Repair a Loose Armrest on a Camping Chair, Screw on the replacement: 4 단계, 이미지 3/3
    • Once you have the right replacement, you should screw the piece in the right place.
    • Tip: Make sure the the screw is passing through the cloth part and metal structure of the chair.
    • After securing the new replacement, you can reassemble the other chair arm that was used as an example.
  5. How to Repair a Loose Armrest on a Camping Chair, Finished and ready!: 5 단계, 이미지 1/2 How to Repair a Loose Armrest on a Camping Chair, Finished and ready!: 5 단계, 이미지 2/2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
회원 가입일: 07/19/23
5,208 평판
안내서 46개 작성하였습니다
INTERSPORT INTERSPORT 회원
Community
16 회원들
안내서 48개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 25
전체 시간: 25
