주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Chip in Laminate Flooring
필요한 것
    1. How to Repair a Chip in Laminate Flooring, How to Repair a Chip in Laminate Flooring: 1 단계, 이미지 1개 중 1개
      • Wipe the chipped area with a damp cloth to remove dust and debris.
      • A clean surface helps the repair compound adhere better and ensures a smoother finish.
      댓글 쓰기
    2. How to Repair a Chip in Laminate Flooring: 2 단계, 이미지 3개 중 1개 How to Repair a Chip in Laminate Flooring: 2 단계, 이미지 3개 중 2개 How to Repair a Chip in Laminate Flooring: 2 단계, 이미지 3개 중 3개
      • Use a knife to cut off enough wood putty to completely fill the chipped area.
      댓글 쓰기
    3. How to Repair a Chip in Laminate Flooring: 3 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 3 단계, 이미지 2개 중 2개
      • Knead the putty for 2 minutes until it reaches a smooth and consistent texture.
      댓글 쓰기
    4. How to Repair a Chip in Laminate Flooring: 4 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 4 단계, 이미지 2개 중 2개
      • Press the putty firmly and evenly to fill the chipped area.
      댓글 쓰기
    5. How to Repair a Chip in Laminate Flooring: 5 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 5 단계, 이미지 2개 중 2개
      • Use a damp cloth to smooth the area before the putty hardens.
      • Allow the putty to set for 30–60 minutes before continuing to the next step.
      댓글 쓰기
    6. How to Repair a Chip in Laminate Flooring: 6 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 6 단계, 이미지 2개 중 2개
      • Prepare matching color repair compound in a small container.
      댓글 쓰기
    7. How to Repair a Chip in Laminate Flooring: 7 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 7 단계, 이미지 2개 중 2개
      • Apply the color to the repaired area with a brush and spread it evenly for full coverage.
      • Use gentle, precise brush strokes to blend the repair naturally with the surrounding flooring.
      댓글 쓰기
    8. How to Repair a Chip in Laminate Flooring: 8 단계, 이미지 2개 중 1개 How to Repair a Chip in Laminate Flooring: 8 단계, 이미지 2개 중 2개
      • Clean the area around the repair to remove excess material and ensure a polished finish.
      • Allow the area to dry for 6–12 hours before walking on it or making any touchups.
      댓글 쓰기
결론
Repairing chips in laminate flooring doesn’t have to be hard or costly. With minimal effort, this repaired flooring looks renewed, lasts longer, and provides a practical solution for everyday wear and tear.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mai Nguyen
회원 가입일: 09/25/25
187 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 179
전체 시간: 1,683
