주요 콘텐츠로 건너뛰기
How to Repair a Christmas Tree Light Wire
필요한 것
  1. How to Repair a Christmas Tree Light Wire, How to Repair a Christmas Tree Light Wire: 1 단계, 이미지 1개 중 1개
    • Unplug the lighting.
  2. How to Repair a Christmas Tree Light Wire: 2 단계, 이미지 2개 중 1개 How to Repair a Christmas Tree Light Wire: 2 단계, 이미지 2개 중 2개
    • Using the wire strippers, split both wires apart approximately one inch.
  3. How to Repair a Christmas Tree Light Wire: 3 단계, 이미지 2개 중 1개 How to Repair a Christmas Tree Light Wire: 3 단계, 이미지 2개 중 2개
    • Using the wire strippers, strip about an inch of insulation off of each wire.
    • Use appropriate wire gauge when stripping. A good practice is to start with large gauge and work your way down.
  4. How to Repair a Christmas Tree Light Wire: 4 단계, 이미지 2개 중 1개 How to Repair a Christmas Tree Light Wire: 4 단계, 이미지 2개 중 2개
    • Twist all four copper strands.
    • This will make it easier to work with and help prevent fraying.
  5. How to Repair a Christmas Tree Light Wire: 5 단계, 이미지 1개 중 1개
    • Insert the heat shrink tubing on the longer end of your wire.
    • Once the heat shrink is on your wire, slide it out of your way. We will address the heat shrink in Step 9.
  6. How to Repair a Christmas Tree Light Wire: 6 단계, 이미지 3개 중 1개 How to Repair a Christmas Tree Light Wire: 6 단계, 이미지 3개 중 2개 How to Repair a Christmas Tree Light Wire: 6 단계, 이미지 3개 중 3개
    • Cross and twist the wires together to create a connection.
    • This helps the wires form a better connection when soldering together.
  7. How to Repair a Christmas Tree Light Wire: 7 단계, 이미지 2개 중 1개 How to Repair a Christmas Tree Light Wire: 7 단계, 이미지 2개 중 2개
    • Solder your wires together by applying heat to the bottom of your wires and solder to the top. The solder will melt onto the copper strands solidifying both wires together.
    • Burn and fire hazard. Take appropriate precautions and solder in a well-ventilated area.
    • Pre-heat soldering iron to 325 Fahrenheit.
  8. How to Repair a Christmas Tree Light Wire: 8 단계, 이미지 1개 중 1개
    • Use electrical tape to wrap the soldered wires.
    • This will prevent both wires from contacting each other.
  9. How to Repair a Christmas Tree Light Wire: 9 단계, 이미지 1개 중 1개
    • Slide the heat shrink over the soldered wires.
  10. How to Repair a Christmas Tree Light Wire: 10 단계, 이미지 1개 중 1개
    • Use your heat source to apply heat to the heat shrink.
    • Apply heat from heat appliance half an inch away from heat shrink.
  11. How to Repair a Christmas Tree Light Wire: 11 단계, 이미지 2개 중 1개 How to Repair a Christmas Tree Light Wire: 11 단계, 이미지 2개 중 2개
    • Connect your Christmas tree plug into the outlet.
결론
You've completed soldering and properly covered any exposed wires being worked on. Connect your cable to an electrical outlet; you're Christmas tree is ready to light once again.
작성자
2다른 기여자 명과 함께
Javi Becerra
회원 가입일: 03/01/23
199 평판
안내서 1개를 작성함
1가이드 댓글
You can also offset the lengths of the twin wires so the joints aren't next to each other for more protection from a short.
pdb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 81
지난 30일: 315
전체 시간: 1,862
