주요 콘텐츠로 건너뛰기
How to Repair a Cooluli Classic-4L That Won't Cool
필요한 것
  1. How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 1 단계, 이미지 3개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 1 단계, 이미지 3개 중 2개 How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 1 단계, 이미지 3개 중 3개
    • Remove the plastic basket and tray from the inside of the refrigerator by sliding them out of the holders.
    • Remove any and all products from inside of the refrigerator.
    • If you have any perishable products in your Cooluli Classic-4L, temporarily store them in another refrigerator.
  2. How to Repair a Cooluli Classic-4L That Won't Cool: 2 단계, 이미지 1개 중 1개
    • Place the refrigerator on a flat surface with a towel beneath it to catch any water that drains out during defrosting.
  3. How to Repair a Cooluli Classic-4L That Won't Cool: 3 단계, 이미지 1개 중 1개
    • Leave the refrigerator overnight with the door open to allow the inside to defrost.
  4. How to Repair a Cooluli Classic-4L That Won't Cool: 4 단계, 이미지 2개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool: 4 단계, 이미지 2개 중 2개
    • After the refrigerator has defrosted overnight, clean the inside of the refrigerator with warm water and liquid soap.
    • Dry thoroughly with a soft cloth or paper towels.
    • If there is still ice on the inside of the refrigerator, wipe away with a warm, damp cloth.
    • Do not chip away at the ice with a hard object, as you may damage the plastic lining of the inside of the refrigerator.
  5. How to Repair a Cooluli Classic-4L That Won't Cool: 5 단계, 이미지 3개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool: 5 단계, 이미지 3개 중 2개 How to Repair a Cooluli Classic-4L That Won't Cool: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the six 4 mm screws from the plastic back cover of the refrigerator.
    • Gently move the cover away from the back of the refrigerator once all of the screws are removed.
  6. How to Repair a Cooluli Classic-4L That Won't Cool: 6 단계, 이미지 3개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool: 6 단계, 이미지 3개 중 2개 How to Repair a Cooluli Classic-4L That Won't Cool: 6 단계, 이미지 3개 중 3개
    • Wipe away any dust and dirt from the ventilation fan with a dry cloth or paper towel.
    • You can use a cotton swab to clean the smaller corners of the fan.
  7. How to Repair a Cooluli Classic-4L That Won't Cool: 7 단계, 이미지 3개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool: 7 단계, 이미지 3개 중 2개 How to Repair a Cooluli Classic-4L That Won't Cool: 7 단계, 이미지 3개 중 3개
    • Replace the back cover of the refrigerator.
    • Place the six 4 mm screws in the holes of the back cover, then screw in with the Phillips #000 screwdriver.
  8. How to Repair a Cooluli Classic-4L That Won't Cool: 8 단계, 이미지 3개 중 1개 How to Repair a Cooluli Classic-4L That Won't Cool: 8 단계, 이미지 3개 중 2개 How to Repair a Cooluli Classic-4L That Won't Cool: 8 단계, 이미지 3개 중 3개
    • Put the removable tray and basket back into the refrigerator.
    • Plug your refrigerator into an external power source.
    • Place your products back into the refrigerator.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Olivia Arredondo
회원 가입일: 10/09/21
319 평판
안내서 1개를 작성함
19가이드 댓글
What if it has stopped cooling but there is no ice buildup??
Janell Gill - 답글
Mine doesn't have frosting either but all of a sudden it stopped cooling. The air vent is not blocked or anything. I had it for a year and a half working just fine and all of a sudden it stopped working. And now the green light blinks when I turn it on.
Barbara Pažur -
Same. Just stopped working. Great lil fridge too.
Green light is not working or on at all. Was a little dust buildup but nothing overwhelming.
Might be done.
J Dog -
Mine cools but sounds like a jet engine taking off; how to fix?
KR4i7 - 답글
I have a problem with my vanity planet fridge not making a tan noise , it stopped cooling I cleaned it today and put it back and now the fan is very very quiet what do I do?
Stefani Ivanova - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 93
지난 30일: 382
전체 시간: 43,584
