주요 콘텐츠로 건너뛰기
How to Repair a Crack on a Vittorazi Moster Exhaust
필요한 것
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 1 단계, 이미지 1/3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 1 단계, 이미지 2/3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 1 단계, 이미지 3/3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: 5 단계, 이미지 1/2 How to Repair a Crack on a Vittorazi Moster Exhaust: 5 단계, 이미지 2/2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: 6 단계, 이미지 1/1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: 7 단계, 이미지 1/1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: 8 단계, 이미지 1/2 How to Repair a Crack on a Vittorazi Moster Exhaust: 8 단계, 이미지 2/2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: 9 단계, 이미지 1/2 How to Repair a Crack on a Vittorazi Moster Exhaust: 9 단계, 이미지 2/2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: 10 단계, 이미지 1/2 How to Repair a Crack on a Vittorazi Moster Exhaust: 10 단계, 이미지 2/2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: 11 단계, 이미지 1/1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
결승점
Darrell Gonzalez
회원 가입일: 09/20/21
207 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 21
전체 시간: 1,067
