주요 콘텐츠로 건너뛰기
How to Repair a Cracked Flower Pot
필요한 것
  1. How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: 1 단계, 이미지 1/2 How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: 1 단계, 이미지 2/2
    • Remove any contents from the pot.
  2. How to Repair a Cracked Flower Pot: 2 단계, 이미지 1/1
    • Apply craft adhesive along the broken portion of the pot.
    • Warning: your adhesive may be flammable. Carefully read the cautions listed on your adhesive before proceeding.
  3. How to Repair a Cracked Flower Pot: 3 단계, 이미지 1/3 How to Repair a Cracked Flower Pot: 3 단계, 이미지 2/3 How to Repair a Cracked Flower Pot: 3 단계, 이미지 3/3
    • Begin to apply glue onto the broken pieces.
    • Once you apply glue to a piece, attach it to the pot.
  4. How to Repair a Cracked Flower Pot: 4 단계, 이미지 1/3 How to Repair a Cracked Flower Pot: 4 단계, 이미지 2/3 How to Repair a Cracked Flower Pot: 4 단계, 이미지 3/3
    • Scrape away the excess glue on both the outside and inside of the pot with scrap paper.
    • Make sure to do this before the glue dries completely.
  5. How to Repair a Cracked Flower Pot: 5 단계, 이미지 1/2 How to Repair a Cracked Flower Pot: 5 단계, 이미지 2/2
    • Use a shoelace or twine to tightly hold the pot together while it dries.
    • Depending on your glue, drying time may take up to 24-72 hours.
  6. How to Repair a Cracked Flower Pot: 6 단계, 이미지 1/3 How to Repair a Cracked Flower Pot: 6 단계, 이미지 2/3 How to Repair a Cracked Flower Pot: 6 단계, 이미지 3/3
    • Once your adhesive has finished drying, remove the shoelace or twine.
  7. How to Repair a Cracked Flower Pot: 7 단계, 이미지 1/2 How to Repair a Cracked Flower Pot: 7 단계, 이미지 2/2
    • Return your plant to its pot.
결론
Now your flower pot is fixed and ready to be used!
다른 한 분이 해당 안내서를 완성하였습니다.
Irene Amuyunzu
회원 가입일: 10/26/18
148 평판
안내서 1개 작성함
UC Davis, Team S1-G6, Bender Fall 2018 UC Davis, Team S1-G6, Bender Fall 2018 회원
UCD-BENDER-F18S1G6
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 40
전체 시간: 3,235
