주요 콘텐츠로 건너뛰기
How to Repair a Damaged Action Figure
필요한 것
  1. How to Repair a Damaged Action Figure, How to Repair a Damaged Action Figure: 1 단계, 이미지 1/1
    • Clean the figurine and wash your hands before starting.
  2. How to Repair a Damaged Action Figure: 2 단계, 이미지 1/1
    • Identify the broken parts and apply a small drop of super glue on the area needing a fix.
    • CAUTION: AVOID DIRECT SKIN CONTACT WITH THE GLUE. Glue can cause skin irritation or burns.
  3. How to Repair a Damaged Action Figure: 3 단계, 이미지 1/2 How to Repair a Damaged Action Figure: 3 단계, 이미지 2/2
    • Press the two pieces together and make sure they match. Hold them together tightly for 2 minutes.
    • If any glue leaks outside when pressing, use an alcohol wipe to clean it.
  4. How to Repair a Damaged Action Figure: 4 단계, 이미지 1/1
    • Let the glue settle and dry for a minimum of 1 hour.
  5. How to Repair a Damaged Action Figure: 5 단계, 이미지 1/1
    • Use acrylic paint as necessary for patching chipped sections of the plastic.
  6. How to Repair a Damaged Action Figure: 6 단계, 이미지 1/1
    • Allow the paint to fully dry before attempting to move or adjust the figurine.
    • You can use hair dryer to speed up the drying process.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anabela Stewart
회원 가입일: 01/31/23
142 평판
안내서 1개 작성함
UC Davis, Team 3-8, Andersen Winter 2023 UC Davis, Team 3-8, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S3G8
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 91
전체 시간: 1,715
