주요 콘텐츠로 건너뛰기
How to Repair a Damaged Heel Lining
필요한 것
  1. How to Repair a Damaged Heel Lining, Check the damaged area: 1 단계, 이미지 2개 중 1개 How to Repair a Damaged Heel Lining, Check the damaged area: 1 단계, 이미지 2개 중 2개
    • Check size and shape of damaged heel lining.
    • Prepare the scissors and the self-adhesive patch.
  2. How to Repair a Damaged Heel Lining, Mark the replacement patch: 2 단계, 이미지 2개 중 1개 How to Repair a Damaged Heel Lining, Mark the replacement patch: 2 단계, 이미지 2개 중 2개
    • Hold the patch against the heel from the outside.
    • Mark the size of the heel with textile chalk and draw a straight line from the mark.
  3. How to Repair a Damaged Heel Lining, Cut the replacement patch: 3 단계, 이미지 1개 중 1개
    • Cut the patch along the marked line.
  4. How to Repair a Damaged Heel Lining, Prepare the attachment of the patch: 4 단계, 이미지 2개 중 1개 How to Repair a Damaged Heel Lining, Prepare the attachment of the patch: 4 단계, 이미지 2개 중 2개
    • Remove the inner sole.
    • Carefully remove the cover paper from the patch.
  5. How to Repair a Damaged Heel Lining, Attach the patch to the heel: 5 단계, 이미지 3개 중 1개 How to Repair a Damaged Heel Lining, Attach the patch to the heel: 5 단계, 이미지 3개 중 2개 How to Repair a Damaged Heel Lining, Attach the patch to the heel: 5 단계, 이미지 3개 중 3개
    • Hold patch with both hands to avoid wrinkling.
    • Place the patch onto the heel. Start from the bottom and press it firm against the lining.
    • Reinsert the inner sole.
  6. How to Repair a Damaged Heel Lining, Finished and ready!: 6 단계, 이미지 1개 중 1개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 29
지난 30일: 167
전체 시간: 2,801
